My Canon digital (still) camera saves movies in Motion JPEG AVI files (I verified this with G-Spot). I figured TMPGEnc would be the surefire way to convert these AVI files to MPEG-1 files, but when I try to open one of these movie files in TMPGEnc, I get an error about the file not being supported. However, I can play these files in Windows Media Player without any problems.
Is there a way to get TMPGEnc to recognize Motion JPEG AVI files? If not, how should I do this conversion?
OK, so now I've run into a problem with SUPER. The MEncoder encoder is garbage - every video I convert becomes much darker and it's hard to see anything. The ffmpeg encoder works nicely most of the time, except that for some of my files, the output MPEG file has a black screen for the video. The only thing in common with these files is that they are short (less than 10 seconds), whereas all the "working" video files are longer.
Any ideas? -
Have you tried change the directshow reader priority in tmpgenc under Option->Environmental settings->VFAPI plug-in? Move it to the top of the list. If you use tmpgenc or tmpgenc plus and not tmpgenc xpress.
In my VCD days, the AVIs TMPGEnc couldn't load naitvely, I loaded in VirtualDub instead, and frameserved to TMPGEnc. Solved most issues for me.
/Mats
AVCHD (1080i) ve Motion JPEG (HD)
By pemongillo in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2011, 21:05 -
AVI Motion JPEG to x264 in Matroska MKV container
By Michielvsb in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 04:12 -
Best Conversion from AVI (Motion JPEG) to MP4
By cademichaels in forum Video ConversionReplies: 3Last Post: 12th Apr 2010, 22:34 -
How to convert to AVI Motion JPEG?
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 17:59 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 18:02
