    Feb 2007
    I am trying to take some of my AVIz...and Trim the Intro and Outro of the episodes....
    I have Anime Eps that Were taken off my DVD because the DVD got thrashed by my little bro...So My buddy put AVIz of the Bleach Anime Eps onto a cd so I dragged and dropped them on my pc and I have been trying to edit them with VirtualDub and VirtualDubMod but to no luck. I keep getting and error message....
    Here is some pix of the G-Spot Stats on one of the avi'z and also some of the errors I am getting...My system was just recently revamped so I believe that some of my files got messed up so I re-download and installed both VirtualDubs...
    Here is some of the pix...sorry about the size of them...
  2. Try a different version of Xvid or Divx.
    Feb 2007
    How would I do that?
    Convert them with SUPER what would be the settings?
  4. Mod Neophyte redwudz's Avatar
    USA
    Uninstall your present version of Xvid and install a newer version: https://www.videohelp.com/tools/XviD_Codec
    Your present version may be corrupted. If you are using a Xvid codec, SUPER will still be using a Xvid codec if that's the format you are converting to.
    A guide for SUPER: https://forum.videohelp.com/images/guides/p1608146/basicsuperguide.pdf
    For tips on using the Xvid codec: http://www.divx-digest.com/articles/xvid_setup.html
    Feb 2007
    I think it is corrupted...so how would I Uninstall Xvid and Reinstall??
    I have a 13 in TV and I watch the DVD-Rz on my PS2....
    I use the following Programs...But I forgot what the settings are...for it...
    I have...Fit2CD, VirtualDub, VirtualDubMod, ConvertXtoDVD....
    Please can someone help me put them onto DVD-R Please...I was able to use them in this order I believe....
    VirtualDubMod to make into Trimmed AVI via...Xvid 4 Mpeg Codec and Full Processing Mode...Then Open it in Fit2CD and change blocks to 2....then open convertxtodvd and hit convert so it saved on my hard drive via VIDEO_TS File...then burn via IMGBurn...
    I think some of my Fit2CD and VirtualDubMod Settings got screwed up though....
    So please help
