I have 16 episodes of the original Transformer cartoons from the 80's. They are in Divx format at about 180 megs a episode. What would be the proper path to take to get these on a dvd disk. It would be nice to have them all on one disk, but 2 would be fine.
Should I get a program to convert divx to mpeg2, then another to create the menus and author the dvd? Or should I use a all in one program like TMPGenc dvdauthor with divx?
The reason I'm asking is the first attempt I used tmpgenc dvdauthor. I imported the clips and let it do everything and I only got 4 episodes on a 4.7 disk. My next attempt, I used convertxtoDVD to convert all 16 files to mpeg 2. Convertx made 500meg files from the clips. I then used tmpgenc dvdauthor16 to author the dvd. I got 8 episodes on this disk.
Any suggestions? Am I headed in the right direction?
The proper way is to get a DivX DVD Player or find the original Transformers on a DVD release.
I would probably convert with a separate encoder like hc encoder where you can set the bitrate to get the output size you want and also tweak encode settings and then use TDA. But it all depends how much time you are willing to spend, if you are happy with convertxtodvd and tda3 then it's enough for you.
And can't you set the video bitrate in tda 3? So you could squeeze in more episodes and still use the tmpgenc converter. -
TMpgenc DVD AUthor 3 should be able to create a divx disc with menus. Or else if you don't want menus(DivX menus can only be played by divx ultra dvd players) you just burn the divx avi files on a dvd.
DVD Dab recently gone bananas? Loses path to burner after each use.
By video_noob in forum DVD RippingReplies: 0Last Post: 25th Sep 2010, 17:32 -
best way to rip cartoon dvd's
By earto in forum DVD RippingReplies: 0Last Post: 6th Oct 2008, 05:13 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 01:24 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24 -
DivX DVD with menu
By Cico Mico in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2007, 03:37
