Results 1 to 9 of 9
Thanks. Under status it says codec are not installed but I just installed DScaler MPEG Filters. Is that the wrong one?
I don't know how to check the fps of the source file. the file extension is h264. i loaded it in gspot but the fps box was empty. I converted to NTSC. I finally have an mpeg2 codec installed but the videos are still not smooth. I tried using vlc, mpc, and powerdvd.
edit: I opened the mkv file with media info and the video info is 720*480, 23.976 fps, mpeg-4 AVC (NTSC). I opened the m2v file in media info and under first video stream it's 8000 kbps, 29.970 fps.
Was I suppose to convert with 23.976 fps? If so, how do I change this in FAVC? -
FAVC will have encoded a 23.976 fps m2v and then used pulldown to convert to 29.97 fps. It's a commonly used standard.
Try watching the DVD on your TV and see if you notice.
Alternatively you could go to the advanced scripting tab and tick "Don't Run DGPulldown". Frame blending may look nicer to your eyes. -
I still got the same results on the dvd player. I checked Don't Run DGPulldown and it didnt help. It only jitters when some scenes pan in a vertical or horizontal direction. I used dvd flick to convert the video and the jitter is gone but the quality is not very good. I guess i could live with the jitter but i wish there was some way to fix it.
You could try a different codec, such as coreavc. There have been a number of posts recently with users having trouble with h.264 files, the problem is almost always resolved by switching codecs to coreavc.
Of course it could also be pc hardware related (you don't have your computer details listed), but codec is most likely.Google is your Friend
VLC not playing mkv(720p, h264) files smoothly?
By swalih in forum Newbie / General discussionsReplies: 15Last Post: 9th Mar 2012, 20:31 -
avchd files wont play smoothly (and some others)
By lordhutt in forum Software PlayingReplies: 21Last Post: 15th Dec 2009, 19:59 -
DVD split with DVDFab. Movies don't run smoothly, goes back to first scene
By whenloverageswild in forum DVD RippingReplies: 1Last Post: 15th Jul 2009, 14:16 -
Any new DVD DivX players which handle packed bitstream smoothly?
By tzikeh in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Dec 2007, 20:13 -
How to get these files to play smoothly?
By Lurkin in forum Software PlayingReplies: 3Last Post: 21st May 2007, 23:00
