Hi am making a DVD in Sony DVD architect 3.0 from a bunch of video clips and here is my question, probably a stupid one tooIs there a way to make every clip a chapter on the DVD? When i just add them in to the project they become tracks and then i cant skipp to the next clip by pressing the skip button when i play the DVD.
Is there a smart way of doing this? I was hoping that i wouldnt need to make all my clips into one big video file and then add that to the project and THEN add chapters to it.
Thx / MTy
If you are familiar with PGCEdit, import your finished output from architect into it and edit commands to do what you want.
There is also DVD Lab with multiPGC title where you import your clips, they will appear as one title but can be accessed as chapters.
Or you can join clips into one with TMPGEnc Xpress or similar software and import to architect to make DVD with chapters. -
What you are trying to do is wrong from a DVD point of view, because what you have are different titles. Chapters are points within a single title.
Tinker's suggestions will all work, or you could look at Tmpgenc DVD Author, and put all your clips on a single track.Read my blog here.
ok so im testing this PGCEdit you recommended but i have no idea where to start modifying
Iv loaded the DVD files from Sony DVD architect and then what? You'll have to lead me in this jungle of buttons and textareas
thx / MTy -
If you do not know anything about DVD commands and structure I would recommend to join the files and make chapters later, if that what Architect need.Originally Posted by tinker
No offence, but to lead you through without seeing what commands are set by Architect and without you having any knowledge of the structure and commands is almost impossible.
If you are going to make quite a bit of DVD in future I would suggest to stay away from these simple to use authoring applications and try DVD Lab Studio for starters. It has a 30 day trial.
Found this in other thread:
http://www.romskye.com/GP/gp003playselect.pdf
Why does Sony DVD architect blow up movie files so largely?
By smythotech in forum Authoring (DVD)Replies: 3Last Post: 17th Aug 2011, 18:52 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
Replacing video in Sony's DVD Architect
By younso in forum Authoring (DVD)Replies: 2Last Post: 26th May 2010, 12:29 -
Sony DVD Architect 4: Long pauses between video titles
By mltwitz in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 20:39
