Hi, I'm new at this so bare with me please
Thanks for your help in advance.
I used ConvertXtoDVD to convert a bunch of AVI files to DVD format.
The conversion worked, and although the quality wasn't great, looks ok...however, there is major audio lag of about 2seconds when I watch the DVD.
Why is this?? How can I fix it? Did I do something wrong?
That can happen for many reasons. Most likely, the audio is encoded with variable bitrate settings. Another reason could be bad frames in the video.
The easiest thing to try would be to run your AVIs through DivFix++ http://divfixpp.sourceforge.net/
see if the fixed avis are still in sync after Divfix++, then try encoding the fixed files through ConvertX
Make sure you're running the latest version of ConvertXtoDVD. Also, check their forum. -
Fixes minor problems. Larger errors are better fixed by slicing the video into smaller parts, then working on each segment.
tsMuxeR and Audio Lag
By imrealdumb in forum Video ConversionReplies: 3Last Post: 14th Jun 2011, 18:28 -
Audio lag after conversion to DVDmpeg2enc
By macgurl in forum ffmpegX general discussionReplies: 5Last Post: 8th Aug 2010, 02:42 -
convertx audio
By denis1213 in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2010, 22:08 -
DVD RIP, Audio and Video Skip/Lag
By Blue_3 in forum DVD RippingReplies: 4Last Post: 8th Apr 2008, 07:34 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03
