Hey all, I'm sure this has been asked, but I was wondering how DVD recorders will be affected when analog receivers are replaced by digital in 2009? Will the recorder be obsolete, will it only record a fraction of content to a disc (2 hours on a analog = ???? hours on a digital), etc...?
There are already DVD recorders with Digital Tuners. All I have seen are SD so no change to capacity..
On analog recorders, since the inputs will not change, the DVD recorder will behave exactly as it does now. You will need an analog input from a Digital Converter Box. -
I already do this. I run s-video from an SD settop box to the DVDR and images that are far better than I get from the built-in analogue tuner. The issue one of convenience, as I have to make sure the digital box is on the right channel when recording from the timer. I also get true 16:9 anamorphic recordings through the s-video.
Read my blog here.
A DVD recorder with analog tuner will no longer tune over the air channels after 17 Feb, 2009 but will continue to tune analog from cable or accept set top box output over S-Video or composite. Over the air tuning will require an external ATSC tuner.
Originally Posted by handyguy
Digital to analog channels
By ady57590 in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 07:19 -
analog to digital tv tuner
By bkapca in forum Media Center PC / MediaCentersReplies: 3Last Post: 14th Jan 2010, 12:32 -
Convert analog & digital tapes to Flash/.flv, no DVD - How would you do
By dsutton in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2009, 17:27 -
Analog vs Digital TV
By J. Baker in forum Newbie / General discussionsReplies: 9Last Post: 10th Jan 2009, 03:21 -
analog to digital and then edit
By doogy777 in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2008, 20:45
