My MacPro has been behaving oddly for a few weeks:
MacParDelux now has the feever:
in downloading a file from newsgroup "a" and using MPD the Par2 is reffering back to a completely different file system that came from a very different newsgroup.
I torrented something else, and the AZ torrent thought it was a file from EZ 7z
Bummer.
any ideas? through the whole thing out?
unfortunately I can't find my Mac 10.4 install DVD'S to boot from them and try reparing the permissions and fixing and repairing the boot HD.
you help much appreciated!
BTW: just ordered 10.5!
cheers
	MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 QTPro, MPEG2 add on MPlayerX2
 MPEG Streamclip
 24 + 21" samsung flat panels
 G4dual 2GB
 AlchemyDVR card
	What makes you think it's not user error on part of the poster?Originally Posted by rotuts
 So? Get 7zX and unzip.Originally Posted by rotuts
 Kinda important to know where your OS discs are... right up there with knowing where your towel is.Originally Posted by rotuts
 You don't need to reboot to verify or repair permissions with Disk Utility.
 You can verify (but not repair) disks without rebooting with Disk Utility. At least you'll know if something's wrong.
 From what you're describing, I'm not convinced that your system is hosed, or any app for that matter.
	thanks for your reply
 I did repair the permissions and the AZ torrent was re-downloaded and worked fine w the ususal icon. it was never a EZ file. I tried that. so while did it 'change' the icon?
 the PAR2 file now refers to the second series of DL's from that same newsgroup ( D1, D2) is now all to D2 so that may indeed be a posters error. before it referred to a file long DLd a while ago to my HD that didn't even come from a NG.
 if I check to see if my HD needs repair w the Utilities while booted, will it be able to tell if something is wrong even though it can't repair a mounted drive
 and you are absolutely correct that my install DVD's are more important than my towel.
 fortunately I think I know where the towel is. maybe!
 looking now!MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	rotus,
 was the torrent file from the EZ-TV group of torrents?
 I've had a few of those trunecate when downloaded,
 and that would make it think it was .ez instead of
 lol.ez-tv.avi for instance.
 Reboot the drive and run fsck -y -f or reboot from
 the utility CD. Yes, it will stop your downloading for
 all of 5 minutes, but would you rather lose 5 minutes
 or XX amount of torrents/data?
 think about it.....
 What I've seen happen in an instance similar to what you're describing
 Rotus, is if EVERYTHING is going to to the same location.
 You can, or at least should, target everything to one drive, but
 target it down to specific subfolders.
 For instance, I have a drive that is called DOWNLOADS.
 within that drive I have three subfolders, labeled,
 Azareus, NG, and Web. Firefox targets web, Azareus torrents
 dl and seed from the Azareus folder, and NG is the default target for
 Thoth.
 Now, I also take it a step further with the NG folder, and save all
 my downloads from Thoth into sub folders within the NG folder,
 so that all pieces I know for say, countdown30.rar through
 countdown30.par are in the same folder, thus avoiding any confusion
 on Thoth's or MPD's fault.
 my 02¢."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	thanks Terryj
 I repaired my permissions as noted above and rebooted. still looking for the MacPro 10.4 install. its near my towel, maybe.
 this may/may not have fixed the torrent issue, but I re downloaded the torrent (From UKTV) and it looked and acted like the standdard AZ torrent.
 all of my torrents go to the same place, and all my NG Pars/Rars go to a different place ( folders) still a bit puzzled why the PAR2 w a set of RARs didn't try to unRAR the 'supposed' rars of the same name and picked a rars set that was sitting on my computer for several days as its not yet complete on the NG.
 better believe Ill keep a closer eye on 10.5!
 BTW too bad for aapl: amazon is cheaper and no shipping (same as aapl) and No Tax!
 will wait to go over to make sure my programs work first or try it on a seperate HD!
 cheers and thanks for your input(s)MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	@ leopard: education is even cheaper ($69), and if you bought
 a new mac after October 1st,
 the cheapest ever ($9.95)!"Everyone has to learn, so that they can one day teach."
 Urban Mac User
	where did you get the edu price? I qualify and its 119????
 no new mac here but I did get the Touch for the Gym: those tread mills drive me bananas.
 Now I can watch Ugly Betty!
 cheersMPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
  tsmuxer difficultiesBy GLE3 in forum Video ConversionReplies: 0Last Post: 22nd Apr 2010, 14:06
  Vegas: Frame DifficultiesBy Squid_uk in forum EditingReplies: 8Last Post: 10th Mar 2009, 14:21
  serious conversion difficulties!By bigbadmateus in forum Video Streaming DownloadingReplies: 3Last Post: 28th May 2008, 08:32
  MacPar deluxe 'CPU' hog in a MacPro?By rotuts in forum MacReplies: 9Last Post: 19th Oct 2007, 16:49
  Audio difficultiesBy MCnDaHouse in forum DVD RippingReplies: 4Last Post: 15th Oct 2007, 06:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
