I recently burned some AVI files to a rewriteable DVD and although all of the files burned correctly and look great only the first one plays back with audio. I honestly have no idea where to even begin looking for the problem so any help would be appreciated.
It might help to start with describing what software you used to author and burn the DVD,
I used NTI DVD-Maker 7. I also have CyberLink PowerProducer but haven't fooled around with it yet.
ConvertXtoDVD handles downloaded material best. If you are looking for avi to dvd converter try dvd flick or favc.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
