Hi again, i've recently upgraded to the latest build, i was on v2.0 beforehand.
Whenever i loaded an xvid into the system, i would have to use the "Auto-fit" button say 50% of the time (usually because what i wanted to convert had 2 separate files), the resultant VIDEO_TS folder would usually always come in below 4.3gb.
Now i've upgraded, whenever i load in the xvid's (ok they're not the same ones exactly) i have ALWAYS needed to use the Auto-fit button, and the resultant folder is always around the 4.3gb mark.
Is this down to different encoding methods etc, is it upping the quality of the resultant conversion, or is something else happening ?
Any info appreciated.
Thanks,
Az
ChrissyBoy can correct me if I am mis-remembering, but I think at some point between 2.0 and 2.5 there have been some bitrate ajustments. I don't recall specifics and I may be wrong. Could be the files you are using are different enough in duration than previously to need autofit. Duration has always been the dtermining factor.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Cheap Spongebob DVD player with seemingly odd behavoir
By RBKearnsJr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 30th Jan 2012, 20:21 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 06:23 -
Creating video files larger than 1 GB with mencoder, important hint
By penguin74 in forum LinuxReplies: 1Last Post: 4th Nov 2007, 21:13 -
whats the dl box under auto fit for?
By djspud in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Aug 2007, 19:25
