    Oct 2007
    I downloaded a free trial of movie factory 6 pro, And I would like to capture my analog video camera to dvd I select straight to dvd then analog tv 1 that is the only selection that recognizes dazzle then I select composit my camera is connected to dazzle through a usb port. when I begin to capture I get cannot start the capture graph. capture failed the created file is corrupt and unstable. It will be automatically deleted this happens everytime. It will let me capture tv with no problems. Also I tried to unistall the program but it will not let me in control panel add and remove programs it keeps on telling me I have movie factory 6 installed try to uninstall first. Everytime I try to uninstal it gives me the same messasge. I thought if I reinstalled I would have better results.
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Something is wrong when you can't uninstall it. Sounds like something in the setup. Try uninstalling in through MS-Dos.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    Oct 2007
    Thanks for the reply, but corel sent me direction on how to uninstall the program manually, So I'm going to try to reload the program again, But does anyone have any idea about the first part of my question. Corel did not, they said dazzle is not compatable but my brother has same setup and has no problem, and I can see the video from my camcorder on there software but that is where it ends.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Use the software that came with the card (or latest and greatest from their site) for capture , import into Ulead .
    Problem solved.
