    May 2006
    Germany
    Hi
    I want to make a very short video showing an image which breaks as if it were glass, like a mirror.
    A friend told me that I can do this with the 'bigger' video programs like Sony Vegas or Adobe Premiere Pro. I don't have any of them and I don't intend to buy one for this rather small 'project' so I thought I'd ask here if anyone would be so kind and does this for me.
    I'll give the details if someone agrees who can do this and agrees to help me out.
    Apr 2004
    Miskatonic U
    Do you just want it to crack, or to break into shards and drop ?
    You might be able to do this type of effect in WAX2 from Debugmode.com.
    Read my blog here.
    May 2006
    Germany
    It would look much cooler breaking into pieces and falling down leaving a black screen.
    Thanks for the link, I'll see if I can do it with the program.
    edit: I can't do it >_>
    The first problem is, that it only shatters (as the name of the plugin sais ^^) the image. It doesn't look like as if something hits the image and it breaks down. Next problem is that I can't save any video:
    Unable to create file!
    ** Some compressors require the video frame size to be a multiple of 4.
    ** Try changing your output frame width and height to multiple of 4 pixels and render.
    Rendering over.
    [btw I tried any codec, doesn't work]
    edit2: nevermind, it worked now. Thanks again ^^
  4. This can be done in After Effects using the "Shatter" effect.
  5. Here's just an Example of the near endless possibilities:
    May 2006
    Germany
    Now that definately looks cooler that what I made. Guiboche, if you were so nice to do this thingy for me, please send me a PM and I'll send you the pic and the details.
  7. I'm nice, oh yes, but I don't take offers to create things for people.
    Only becuase all my knowledge comes from visting sites, and doing MANY tutorials all on my own. If I can gain knowledge all by myself, so can others
    www.creativecow.net <--- LOTS of AE stuff here.
    http://library.creativecow.net/articles/unguren_ben/shatter.php <-- The shatter effect
    May 2006
    Germany
    The problem is that I didn't want to buy/pirate a program just for this matter, not that I'm too lazy to do it myself.
    As I said, I did the thing, it just doesn't look that realistic. Right now it's ok after all, but if anyone feels that he/she just has to do it better (with a better program etc) felel free to post here or send me a PM. =D
    Thanks anyway for the link, I'll bookmark it for later use.
