I am trying to rip a foreign language DVD into a VCD/SVCD. How do I get the English translations at the bottom of the movie onto the VCD, they seems to have disappear after I rip them using Smartripper. Can someone show me or just direct me to find the info in the GUIDE.
There are several ways, DVD2SVCD, DVDx and Flask allow you do this. There's a rather good guide at: http://www.flexion.org/video/DVDConv/DVD2AVI/index.html
actually has more info than you need. Basically:
1) Rip DVD
2) Use DVD2AVI to generate D2V and wav file
3) Run Virtual Dub and load the VobSub filter, use filter to extract subtitles
4) Frame serve to TMPGenc, and encode.
There are also guides to the left under Author. These subtitles will be permanant! SVCD supports selectable subtitles, however most stand alones do not
Also the software (Iauthor) is next to impossible to find and only sold in China.
Thanks for the help.
After I generated the D2v file with DVD2AVI, I tried to load it to VirtualDub, but it won't recognize the file. I followed the instructions and converted the D2v file to AVI using VFAPIConv-EN.exe, VirtualDub still won't recognize the AVI file, it tells me that I don't have the Codec. What do I do now? -
I am really stuck. I have followed the instructions in the guide, but VirtualDub won't recognize the avi file generated with VFAPIConv-EN.exe, I have downloaded the latest version of virtualDub and installed the handler, now what? It still won't read the AVI file. Someone pls help.
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 18:48 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 13:45 -
How to put subtitles to a mkv file
By donpato in forum SubtitleReplies: 2Last Post: 6th Apr 2008, 17:17 -
trying to put VCD files on a DVD with MyDVD Express
By curt1sw in forum Authoring (DVD)Replies: 7Last Post: 15th Nov 2007, 15:42
