hi
I just d loaded the free version
of BS Player
I tried to do some caps of a movie
I pressed shift then P
it then said ' frame saved to BS Caps
thats great, but where is bs caps ??
I can t see a folder of that name in my documents
brilliant, thanks a ton , its working now.
I had vlc for past 6 months working fine and
doing caps
suddenly vlc just won t come up
maybe I should delete and redownload the software
but for the moment BS Player is just great
(unfortunate choice of name though ! )
thanks again , you re a star
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Player nightmare! (BS Player and Media PLayer Classic)
By 2710 in forum Software PlayingReplies: 1Last Post: 9th Jul 2010, 06:28 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
