    Oct 2005
    Hi, just a quickie...
    I have my Menu > Video Encoding settings set to "PAL Menu" (with the checkbox checked to show the warning) - I thought this was mainly a problem for US-based people, seeing as our UK DVD players seem to handle NTSC playback without any problem.
    The warning will pop up when i have added a menu but i'm encoding NTSC AVI's, is this something i should worry about ? If so, should i change the setting (for that project only) to NTSC Menu ?
    Thanks,
    Az
  2. It's never caused a problem for me. It's there because some players may have problems with mixed content. Try it and see is my best suggestion.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Oct 2005
    OK, thanks for that.
    Az
