    Oct 2007
    the corner of the global
    A few days ago, I installed a program, which is called MelodyCan. I installed it as if it is a normal application. However, my computer suddenly went black, and it restarted. Then I could not hear any sound when playing videos. I uninstalled the program, but no sound neither. Is there anybody who can help? A little bit desperat with the program.
    Since then, I hear the sound when a message pops up, if there is notice for me to interact. I think I did not get such sound before installing the program.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could try installing the latest audio drivers for your MB/sound card.
    Assuming you are using XP, you can go to Control Panel / Sounds and Audio Devices, Audio tab, and verify the correct device is listed in the drop down box under "Default device". This drop down should have your sound card/driver listed.
    Google is your Friend
    Oct 2007
    Thanks for the information. And I noticed that there is no option under the Default device before installing.
    Quite frustrated when I tried to install the driver, as I mistakenly deleted plug and play software device enumerator.
    Anyway, it works now.
    Thanks.
