Results 1 to 11 of 11
    Mar 2007
    Egypt
    hello
    i want program can open network stream " like vlc " encode it and send it .. mms or http , locan network it
    any program even paid
    thanks
    May 2004
    Mar 2007
    Egypt
    thanks for reply
    Mplayer is hard to learn for newbie like me
    any other program even paid app ?
    May 2004
    SDP Multimedia
    ASF recorder
    If you want to save something from the web, Firefox with the "Unplug" plugin will catch a lot of embedded media.
    Capturing something from the web, recoding it and redirecting to a local network isn't simple.
    Maybe you could be more specific about what you want to do.
    Mar 2007
    Egypt
    again thanks for reply
    i have dvb card .. sky star 2
    i use dvbdream , MyTheatre to watch the channels
    in both program we have remote view option .. send the video to the lane as unicast
    so in vlc ctrl+n to receive and/or encode the video
    i want another program to do this coz .. i try with WME but no success it seems only chapter from file or device as a source
    May 2004
    In VLC you can stream save raw, or encapsulated as , mp1, asf, mp4, avi, mpeg PS, mpeg TS, Ogg, whatever you want. An asf format might be easier for WME to work with.
    Otherwise just stream dump with VLC to your hd as an mp1 if you have the space. mp1's are pretty universal. You can recode later. I am assuming you want to save tv shows for later.
    Mar 2007
    Egypt
    i get very big pixels with vlc .. so i try to get anything else
    and i try to stream the video ..
    WME receive from tv card or something like this .. encode and stream it .. right ?
    but it cant recognize skystar2
    so i search for anything like vlc so i can recive , encode , and stream back the video
    do you know something can let WME recognize skystar2 dvbs card or receive the stream from the lan ?
    May 2004
    If you don't use a cable/sat approved box/card/decoder, then the signal will not be high definition. That's probably why you get 'big pixels' with VLC and the skystar card.
    Your cable/sat company should be able to supply you with a decoder box that has an internal hard drive (TiVo or something like it). Once you have the show or program saved on the hard drive, you can copy it off to your computer and stream it to your home theatre.
    Mar 2007
    Egypt
    dnix71
    thanks for reply
    i receive from nilesat .. its free channel
    after your reply i wait and buy new dvd to try it with vlc
    the same .. big pixels and many square over the picture
    i think its from vlc or i have to change something to make it work fine
    May 2004
    Nilesat is an older satellite repositioned to provide free tv and internet to North Africa. I wouldn't expect a high quality signal from it. The quality of signal will vary with the style and position of the recieiving dish, the cable length, the weather and where you are in it's signal area.
    The software you use won't help you unless you have good reception. You should try to borrow some better hardware from a neighbor and see if that helps, before spending more time and money on software.
    Mar 2007
    Egypt
    dnix71
    many thanks for reply and your help
    im sure now its from vlc coz i try the following
    recode some video and try to encode it with WME , vlc
    with vlc 120 384*288
    with WME 120 384*288
    also 300k for both
    VLC video big pixels and many square over the picture
    WME provide much better quality and clear picture
    and with dvd .. vlc provide the same problem in video
    vlc forum , support cant provide much help .. i think they are busy
    i can spend on software if it will fix this problem and i can stream live .
