Here are the properties of a movie transfered from a Viewsat FTA PVR 7000 Receiver to my PC (properties given by VideoReDo Plus):
File Name: C:\test mpeg PVR - PC\2ND REGARD.MPEG
File Size: 888968079 ( 0.83 GB )
Program Duration: 00:34:59.10
File Type: PS - MPEG2
Encoding: MPEG 2
Video stream Id: xE0
Encoding Dimensions: 544 x 480
Display Size: 544 x 480
Aspect Ratio: 4/3
Frame Rate: 29.97 FPS
Bit Rate: 15.000 Mbps
VBV_Buffer: 224 KB
Profile: Main/Main
Progressive: Prog or Int
Chroma: 4:2:0
Audio Format: Layer 2
Audio Stream Id: xC0
Audio Bit Rate: 192 Kbps
Audio Sampling Rate: 48000 Hz
Is there a way to play this kind of movie on a computer ? I have tried without success: Windows Media Player v10, Media Player Classic 6.4.9, Nero Showtime 3, Real Player v 10, QT, BS Player 2, DivX Player 6.6, VLC 0.8.6 (on both Mac & PC) ?
I've also installed K-Lite Codec Pack without success.
So far, VideoReDo Plus is the only software with which I can open & play properly this kind of movie file.
Is there also a way to convert such a mpeg file into AVI file ?
With all my thanks
Here it is. Media Player Classic freezes after a few seconds & no sound.Originally Posted by Krispy Kritter
Doesn't look like the file uses a normal audio format...at least there isn't one listed. Most likely that is what is causing your players to choke.
FWIW, files taken directly from DVR's/Tivo's etc usually require conversion before they are capable of playback on any device.Google is your Friend
Playing movies from my PC
By rossvickicampbell in forum ComputerReplies: 1Last Post: 16th Jun 2011, 20:56 -
Capturing SD 4:3 Movies with HD PVR
By turbines in forum DVB / IPTVReplies: 2Last Post: 23rd Apr 2010, 08:46 -
Playing in VGA with HD PVR help?
By kILLDR3n in forum Capturing and VCRReplies: 8Last Post: 12th Apr 2010, 08:11 -
problems playing dvd movies
By bexiga in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 20:37 -
HDTV(ComCast) DishNetwork(ViewSat Ultra 2000)
By KrishManohar in forum DVB / IPTVReplies: 6Last Post: 19th Oct 2007, 12:29
