Page 23 of 138
FirstFirst ... 13 21 22 23 24 25 33 73 123 ... LastLast
Results 661 to 690 of 4116
  1. @kayizm
    could you post the <F:\P_7\The.Perfect.Host.2010.1080p.MKV.AC3.DTS. NL .Subs\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL.S ubs\The.Perfect.Host_0_BatchMux.log> as well?
    Bye
    MrC
    AVStoDVD Homepage
  2. AVStoDVD release 2.4.2 is available to download.
    Change log:
    - Some bugs fixed
    - Added possibility to edit source titles media info ('Title'/'Edit Source Title Info')
    - Added a consistency check on special chars to main window 'DVD Label' and 'Title Edit'/'General'/'Title Name'
    - Added custom values saving in (and loading from) Windows Registry from 'Title Edit'/'AviSynth'
    - Added 'Bias' and 'DC Precision' options in 'Title Edit'/'Video'/'HCenc Advanced Options'
    - Improved backup Audio encoding routine (FFmpeg based)
    - Improved input titles format checking routine
    - Wavi updated to 1.06m
    - FFmpeg updated to 32754
    - MediaInfo updated to 0.7.50
    Bye
    MrC
    AVStoDVD Homepage
  3. Member Seeker47's Avatar
    Jul 2005
    Suppose I need to go +3 sec.s on the subtitles (so they will appear earlier, to have better sync with the spoken dialog). How self-evident is that procedure going to be, if I try to arrange it with AVS settings ? Or is it better to do this in advance, by using SubtitleCreator on the .SRT file ? Is there a good way to preview / test the result of this re-sync, before AVS spends an hour or so processing this out to DVD-structure files ?
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  4. @_MrC_
    Here is one that i just tried to complete;
    <11/22/2011 10:03:36 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 7445/8100 MB (92%)
    DVD Output Setup: DVD Folder
    DVD Label: Conan.the.Barbarian
    DVD Menu: No Menu
    Output Folder: F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC. DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MKV .X264.AC.DTS.Eng.NL.Subs
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 1
    Video BitRate Min: 4500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 0
    AC3 Audio Encoder: 0
    PAL SpeedUp: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 448
    Keep DVD Compliant Audio: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 18pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: L: HL-DT-ST BD-RE WH10LS30 1.00
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Display errors messages: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    Save General Settings: 0
    TITLE 1 SOURCE FILES
    Video: F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC. DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MKV .X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbarian.2011. 1080p.MKV.X264.AC.DTS.Eng.NL.Subs.mkv
    Info: AVC - 11190 kbps - 1920x800 - DAR 2.4 - 23.976 fps (CFR) - Progressive - 1:52:42 hours - 162145 frames
    Audio 1: F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC. DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MKV .X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbarian.2011. 1080p.MKV.X264.AC.DTS.Eng.NL.Subs_1.dts
    Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 1:52:39 hours (0 ms delay) - External
    Audio 2: F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC. DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MKV .X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbarian.2011. 1080p.MKV.X264.AC.DTS.Eng.NL.Subs_2.ac3
    Info: AC3 - 640 kbps - CBR - 6 ch - 48000 Hz - 1:52:42 hours (0 ms delay) - External
    Subs 1: F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC. DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MKV .X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbarian.2011. 1080p.MKV.X264.AC.DTS.Eng.NL.Subs_EN.srt
    [MediaInfoLib - v0.7.47]
    <11/22/2011 10:03:37 AM>
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("F:\P_7\Conan.the.Barbarian.2011.10 80p.MKV.X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbaria n.2011.1080p.MKV.X264.AC.DTS.Eng.NL.Subs\Conan.the .Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL.Subs. mkv", CacheFolder="C:\Users\KAYIZM_6\AppData\Local\Temp" , FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("F:\P_7\Conan.the.Barbarian.2011.10 80p.MKV.X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbaria n.2011.1080p.MKV.X264.AC.DTS.Eng.NL.Subs\Conan.the .Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL.Subs_ 1.dts", CacheFolder="C:\Users\KAYIZM_6\AppData\Local\Temp" )
    Video = Video.ConvertToYV12
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.AddBorders(0,140,0,140)
    Video = Video.Spline64Resize(720,480)
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: QuEnc CBR 1-pass
    Target Video FileSize: 6533.5 MB
    QuEnc Parameters: -i "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_Conan.the.Barbarian.2011.1080p.MKV.X264. AC.DTS.Eng.NL.Subs_1.avs" -o "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs.m2v" -b 8104 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
    <11/22/2011 11:22:52 AM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Con an.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL .Subs.m2v (6533.2 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8173 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:52:35 hours - 161981 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
    <11/22/2011 11:25:44 AM>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Con an.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL .Subs.m2v (6533.2 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8164 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:52:42 hours - 162142 frames
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_Conan.the.Barbarian.2011.1080p.MKV.X264. AC.DTS.Eng.NL.Subs_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_1.ac3"
    <11/22/2011 11:31:45 AM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    A2DAudioSource: FFmpegSource2 (cache off)
    Created File: C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Con an.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL .Subs_1.ac3 (361.2 MB)
    OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:52:42 hours (0 ms delay)
    START AUDIO ENCODING OPERATIONS (Track 2)
    Wavi+Aften Parameters: "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_Conan.the.Barbarian.2011.1080p.MKV.X264. AC.DTS.Eng.NL.Subs_2.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_2.ac3"
    <11/22/2011 11:33:12 AM>
    END AUDIO ENCODING OPERATIONS (Track 2)
    A2DAudioSource: DirectShowSource
    Created File: C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Con an.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL .Subs_2.ac3 (361.1 MB)
    START SUBS ENCODING OPERATIONS (Track 1)
    ANSI format conversion routine applied
    SRT fixing routine applied (1 lines fixed)
    SubtitleCreator Parameters: "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_Conan.the.Barbarian.2011.1080p.MKV.X264. AC.DTS.Eng.NL.Subs.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <11/22/2011 11:33:19 AM>
    END SUBS ENCODING OPERATIONS (Track 1)
    Created File: C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Con an.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.NL .Subs_1.sup (0.86 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_BatchMux.ini"
    BatchMux ini file:
    -d "F:\P_7\Conan.the.Barbarian.2011.1080p.MKV.X264.AC .DTS.Eng.NL.Subs\Conan.the.Barbarian.2011.1080p.MK V.X264.AC.DTS.Eng.NL.Subs\Conan.the.Barbarian_0\VI DEO_TS"
    -mxp "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_MuxMan.mxp"
    -l "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_MuxMan.log"
    -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\Users\KAYIZM_6\AppData\Local\Temp\Conan.the.Ba rbarian_0_Palette.txt"
    -v "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs.m2v"
    -vidmode LB
    -a1 "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_1.ac3"
    -a1lang en
    -a2 "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_2.ac3"
    -a2lang en
    -s1 "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_1.sup"
    -s1lang en
    -s1ext 1
    -cellfr "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_Chapters.txt"
    -progfr "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_Chapters.txt"
    -chapfr "C:\Users\KAYIZM_6\Videos\Conan.the.Barbarian_0_Co nan.the.Barbarian.2011.1080p.MKV.X264.AC.DTS.Eng.N L.Subs_Chapters.txt"
  5. @_MrC_
    START PROCESS
    PROJECT SETTINGS
    DVD Menu: No Menu
    PREFERENCES
    MultiThread: 1
    Video Resolution: 1
    PAL SpeedUp: 0
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    Save Log file: 1
    AVISYNTH SCRIPT
    BatchMux ini file:
    -prio LOW
    -vidmode LB
    -a1lang en
    -a2lang en
    -s1lang en
    -s1ext 1
  6. Now for whatever reason, I cant seem to get any audio.
    Mar 2008
    MrC, thanks for the new version. I appreciate the added HCenc options.
  8. @kayizm
    again: could you post the <F:\P_7\The.Perfect.Host.2010.1080p.MKV.AC3.DTS. NL .Subs\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL.S ubs\The.Perfect.Host_0_BatchMux.log>?
    @Seeker47
    not straightforward but possible: add your title, add your SRT, then go to 'Edit Title'/'Subtitles', toggle off 'Auto Subtitles Setup', toggle on 'Hard Encoded', then preview.
    Bye
    MrC
    AVStoDVD Homepage
  9. @_MrC_
    As you wish:
    Segment memory resources --> RELEASED
    Local Stack memory --> RELEASED
    File i/o structures --> DEALLOCATED
    This is all that is in the file!
  10. Originally Posted by kayizm View Post
    @_MrC_
    As you wish:
    Please send me by email (avstodvd@gmail.com) both log files:
    <F:\P_7\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL .Subs\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL.S ubs\The.Perfect.Host_0_BatchMux.log>
    <F:\P_7\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL .Subs\The.Perfect.Host.2010.1080p.MKV.AC3.DTS.NL.S ubs\The.Perfect.Host_0.log>
    Bye
    MrC
    AVStoDVD Homepage
  11. MrC,
    I just sent the files.
    Jan 2011
    Eastern US
    MrC,..I have a problem trying to load Media Player Clasic-HC, I have the path setup to mpc-hc, but when AVStoDVD try to run the preview this is what the program display,..
    LoadPlugin: unable to Load "ffms2.dll"
    (C:\Program Files\AVStoDVD\lib\A2DSource\AviSynth.avsi, line 8)
    (C:\Documents and Settings\my name\Local Settings\Temp\AviSynthP.avs, Line 1)
    I have no idea about trying to troubelshoot this with help.
    Jan 2011
    Eastern US
    MrC, that last line should read,..I have no idea about trying to troubelshoot this without help.
  14. @helidriver
    I would try to uninstall AVStoDVD and AviSynth and then install again AVStoDVD using the Installer Package
    Bye
    MrC
    AVStoDVD Homepage
    Jan 2011
    Eastern US
    I uninstall both and reinstall using the Installer Package (again),..same problem so I went back to Windows Media Player, could not get MPC-HC to work.
  16. Member Seeker47's Avatar
    Jul 2005
    So, it is required to designate a particular player to be used for the Preview function ? In that case, what about VLC ?
  17. @helidriver
    what about using the AVStoDVD built-in player/previewer?
    Bye
    MrC
    AVStoDVD Homepage
  18. Member
    Jan 2011
    Eastern US
    I've used the built-in player,..its ok,..I was looking for a little more from the preview player thats why I was trying to get MPC-HC to work, with no luck I went back to mp2.
    @seeker47, never tried vlc.
  19. Member Seeker47's Avatar
    Jul 2005
    I like MPC-HC, but I keep coming back to VLC. It's basically my 'Go To' player, though MPC-HC would be a close second choice.
    Jan 2011
    Eastern US
    @Seeker47, were you able to get MPC-HC to load with AVStoDVD?, if yes, then how..
  21. I have a problem with .mkv files.
    I start a new project, add source file. Selection for subtitle comes up. I select none but the output file always has subtitles hardcoded into them.
    ie I cant turn them off in MPC-HC etc.
    I might be missing something simple here. Any help appreciated.
  22. Member
    Mar 2008
    It may be being picked up by directshow. If you have a subtitle in the same folder as the movie, and the same name,
    for example:
    mymovie.mkv and mymovie.srt.
    rename the subtitle so that it has a different name than the MKV file and it wont be picked up.
  23. Using AVStoDVD 2.4.2 I burned a movie from AVI and found that the resulting video played back like people and camera are moving in slow motion - though it runs at normal speed. It's hard to describe - as if there are frames missing, producing a kind of choppy, unnatural movement of people and things in the movie. This happens both playing back the dvd on my tv and when playing from the VIDEO_TS file on VLC media player. So the burn is fine, the problem is the conversion to video_ts. The log shows both the source file and output file have 23.976 fps (CFR), and the codec was HCenc VBR 1-pass.
    The original AVI plays fine with natural looking movements.
    Does anyone know what causes this? I assume this is a common problem because I have seen the same sort of thing on movies burned by others, though not as bad as the one I made.
  24. Member
    Mar 2008
    newb0412 - shouldn't be any problem with 23.976 frame rate. Assuming you chose NTSC in the preferences,
    pulldown should be applied to the m2v, giving 29.97 fps at the end. Can you post the whole log ?
  25. I chose NTSC in preferences. I left "Keep MPEG2 DVD Compliant Video" checked as it was checked by default, since I don't know what it means. Here is the log:
    <12/4/2011 8:19:37 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: Burn DVD
    DVD Label: DVD1
    DVD Menu: No Menu
    Output Folder: C:\Documents and Settings\user1\My Documents\My Videos
    PREFERENCES
    MultiThread: 0
    PAL SpeedUp: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Keep DVD Compliant Video: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Subs Language (Primary): PT - Portuguese
    Chapters Interval: 10
    DVD Burning Drive: E: SONY DVD RW DRX-S90U 1.D0
    Auto Erase DVD RW: 0
    Save Log file: 1
    Video: C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.avi
    Info: XviD - 695 kbps - 576x320 - DAR 1.8 - 23.976 fps (CFR) - Progressive - 1:57:17 hours - 168743 frames
    Audio 1: C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.avi
    Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 1:57:18 hours (0 ms delay) - Internal
    Subs 1: C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.br.srt
    Subs 2: C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.en.srt
    [MediaInfoLib - v0.7.50]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.avi", CacheFolder="C:\DOCUME~1\user1\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Documents and Settings\user1\My Documents\Movies\Era Uma Vez\Era.Uma.Vez.2009.DVDRip.XViD.Nacional-Alan_RJ.avi", CacheFolder="C:\DOCUME~1\user1\LOCALS~1\Temp")
    Video = Video.AddBorders(0,2,0,2)
    Video = Video.Lanczos4Resize(720,480)
    <12/4/2011 8:20:12 AM>
    TITLE 1 AVISYNTH FRAMESERVING CHECK
    Check passed successfully.
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 4153.9 MB
    HCenc Parameters: -ini "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Era.Uma.Ve z.2009.DVDRip.XViD.Nacional-Alan_RJ.HCenc.ini"
    HCenc ini file:
    *INFILE C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Era.Uma.Vez .2009.DVDRip.XViD.Nacional-Alan_RJ_1.avs
    *AVSRELOAD
    *OUTFILE C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ.m2v
    *LOGFILE C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Era.Uma.Vez .2009.DVDRip.XViD.Nacional-Alan_RJ.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 4951
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *PULLDOWN
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *NOSMP
    *PRIORITY IDLE
    *WAIT 2
    <12/4/2011 10:47:49 AM>
    A2DVideoSource: FFmpegSource2 (cache off)
    Created File: C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ.m2v (4160.4 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4993 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:57:17 hours - 168742 frames
    <12/4/2011 10:47:50 AM>
    Wavi+Aften Parameters: "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Era.Uma.Ve z.2009.DVDRip.XViD.Nacional-Alan_RJ_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_1.ac3"
    <12/4/2011 10:51:34 AM>
    Created File: C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_1.ac3 (161.1 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:57:18 hours (0 ms delay)
    <12/4/2011 10:51:36 AM>
    SRT fixing routine applied (0 lines fixed)
    SubtitleCreator Parameters: "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Era.Uma.Ve z.2009.DVDRip.XViD.Nacional-Alan_RJ.srt" -p4 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <12/4/2011 10:52:02 AM>
    Created File: C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_1.sup (2.44 MB)
    START SUBS ENCODING OPERATIONS (Track 2)
    <12/4/2011 10:52:21 AM>
    END SUBS ENCODING OPERATIONS (Track 2)
    Created File: C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_2.sup (2.15 MB)
    BatchMux Parameters: -arglist "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_BatchMux.i ni"
    BatchMux ini file:
    -d "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0\VIDEO_TS"
    -mxp "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_MuxMan.mxp "
    -l "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_MuxMan.log "
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_Palette.tx t"
    -v "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ.m2v"
    -vidmode LB
    -a1 "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_1.ac3"
    -a1lang en
    -s1 "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_1.sup"
    -s1lang pt
    -s1ext 1
    -s2 "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_2.sup"
    -s2lang en
    -s2ext 1
    -cellfr "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_Chapters.txt"
    -progfr "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_Chapters.txt"
    -chapfr "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0_Era.Uma.Vez.2009.DVDRip.XViD.Naciona l-Alan_RJ_Chapters.txt"
    <12/4/2011 11:05:33 AM>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4428.6 MB
    vs Estimated Size: 4450 MB -> 0.5% undersize
    vs Assets Size: 4326.1 MB -> OK
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0 (4428.6 MB)
    <12/4/2011 11:05:35 AM>
    START DVD BURNING OPERATIONS
    ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "C:\Documents and Settings\user1\My Documents\My Videos\DVD1_0\VIDEO_TS" /dest E: /volumelabel "DVD1" /speed 4x /testmode no /verify no /noimagedetails /start /waitformedia /close /log "C:\DOCUME~1\user1\LOCALS~1\Temp\DVD1_0_ImgBurn.lo g"
    <12/4/2011 11:23:21 AM>
    END DVD BURNING OPERATIONS
    Created DVD: 'DVD1' in drive E: SONY DVD RW DRX-S90U 1.D0
    Average Write Rate: 4,699 KB/s (3.4x) - Maximum Write Rate: 5,566 KB/s (4.0x)
    Log file created by AVStoDVD Release 2.4.2
  26. Member Seeker47's Avatar
    Jul 2005
    No, I haven't been doing any sort of previewing in AVS, so far. It is something I intend to check out, but is among many things I will have to wait on, due to being very busy right now.
  27. Member
    Mar 2008
    newb04012 - the program is acting as if you don't have an xvid codec installed and it's resorting to ffmpegsource2
    (which may be problematic).
    have you installed any codec pack? If you have uninstall it. Instead install FFDSHOW and haali media splitter.
    https://www.videohelp.com/tools/ffdshow
    https://www.videohelp.com/tools/Haali-Media-Splitter
  28. Originally Posted by davexnet View Post
    for example:
    The only thing contained within the source folder is the .mkv file
  29. Member
    Mar 2008
    d3xp2pc - I did an experiment, created a five-minute MKV, one audio stream and two subtitle streams.
    I deselected both subs in AVStoDVD, but like you, the hard coded subs appear in the DVD output.
    It's not AVStoDVD's fault. The mechanism is similar to as I described earlier,
    a directshow subtitle filter (ffdshow/subtitle or dvobsub,etc,etc) is merging the subs into the video.
    Two solutions that I can think of; disable the subtitle dshow filter, or in AVStoDVD, before starting the project,
    enter preferences/avisynth and select FFmpegsource as the AVS source filter. Now add you file and encode.
    (It may take 5 - 10 minutes to build the index using this method. Eventually you'll see the encode window)/
  30. Originally Posted by davexnet View Post
    Ok thanks for the reply. I will give that a try. Thank you. Sorry might be a noob question but how do I disable the subtitle dshow filter?
