Change the video and audio source filters to FFmpeg and retry (Preferences/Avisynth tab)
Results 3,871 to 3,900 of 4116
The error is an FFmpeg error (not AviSynth), and it occurs when FFmpeg tries to encode a thumbnal video for the menu. When using motion menus AVStoDVD always uses FFmpeg to encode the menu video, even if HCenc is the specified encoder. Unfortunately this encode does not appear in the log, so it is hard to debug.
A reliable way to get rid of the error is to use static menus instead of motion menus. One possible reason for the error could be that your source files have variable frame rate, and I don't know if FFmpeg handles the conversion to the thumbnail videos correctly. -
If you want to sharpen video, try LSFMOD. Its a pretty old script now, but still achieves very good sharpening results and is pretty fast using avisynth+ and the prefetch() command
Prefetch(4) works best for me and never fails, where prefetch(8) is a good few frames quicker but can cause problems with random crashes
To use LSFMOD a simple "video = video.lsfmod(strength=120)" . Thats the settings I use, just before a resize function is the preferred way but will be a lot slower with 4k source. Trying it after a resize will be quicker but slightly less quality
I created a text file with all the filters needs and just put that in the avisynth plugins folder as an .avsi file so it loads it automatically, and I have a BIG list of filters/scripts I use as and when. All work fine when needed with no problems with filters missing
http://avisynth.nl/index.php/LSFmod
This is the very latest update of the script, now supports HBD and fixed a couple of bugs and optimizations
https://pastebin.com/eE37iYWZ -
Another year is almost over...
Time to wish everyone on this forum, and especially those who still do DVD conversions, a Merry Christmas and a Happy New Year...
Very special greetings to MrC, the author of this wonderful software. He has not posted here for some time, so I hope that he is doing well. All my best wishes for him and his family...
Cheers
manolitoLast edited by manolito; 21st Dec 2019 at 21:03.
Your Raw.txt file is not too helpful. Please upload a small section of your source file...
@ digicube
Your sample works nicely in AVStoDVD without any errors. It works with the default A2DSource filters (which use DSS2Mod for video and DirectShowSource for audio), and as davexnet posted, the FFVideoSource filter also causes no problems. I even tried LSMASH without any issues.
So I am quite sure that there is a problem with the A2D configuration on your computer. Please post your A2D log file... -
Have a look at Win7DSFilterTweaker, sometimes the LAV filters are not set by default and 64-bit filters may not be either. This tool guarantees filters are set to what you want not what Windows thinks should be set. It should also work with Windows 10 as well. I just set all filters to LAV and have no issues. Just run it and click the Preferred Decoders button to see what is enabled and change to LAV Filters if its not set. Click Apply & Close and then exit. They are set straight away without any need to restart Windows
https://www.videohelp.com/download/Win7DSFilterTweaker_6.3.exe -
Yes just don't go through DVD Menu Wizard. The DVD will have no menu. If you did, then just click reset menu to delete the menu.
Just add the .idx files so long as they are in the same folder as the associated .sub files. The program will take care of the rest.
I've also found that if you want forced subtitles for a non-English or whatever audio or non-English parts in a film/series (The Great Wall for example), then going into the subtitles tab in the project settings and untick 'auto subtitles setup' then choose 'FORCED' in the drop down menu it works everytime
manolito... is your patch thing still needed for this app ?
what is the download link ?
thanks -
My plugins for AVStoDVD were never needed to run the software. They were always meant for advanced users who want some additional features. Most of them were written as a reaction to user requests. And they are not for noobs because they are not integrated transparently into the program, they require that users edit text files in Notepad and know how to use a file manager in Windows.
A while ago I consolidated my plugins into one single download. You may want to bookmark this link:
https://forum.doom9.org/showthread.php?p=1814958#post1814958
At the bottom of this post you find the relevant download links.
I have been using the latest 2.8.9 Alpha version since it came out, and IMO this version is as stable as it gets. It may even be the final version since MrC has not posted anything since June 2019.
Cheers
manolito -
Maybe a little bit late to be asking this question, but is there any established rule of thumb as to whether the FFMPeg encoding choice (CBR) -- vs. HCenc 1-pas, vs. HCenc 2-pass encoding (both VBR) -- would be likely to yield the best results, per particular video sources ? Or do you just have to experiment with this, because there really are no reliable guidelines ? Though I've been using AVS successfully for a number of years, this is something I never had a lot of insight into. I always thought that HC 2-pass could improve the rendering of lower res sources, &/or sources with highly varying degrees of onscreen action, occasional presence of effects shots etc., and from what I recall that has mostly been the case, especially for the lower res stuff.
A sort of example: the other night I started watching the video file of a 1964 black and white film. (I think it was an .AVI, but would have to go back to check on that.) It had very good cinematography, and looked plenty sharp. For some unknown reason, playback on the player box I was using (WD Live, which is most often very dependable) simply stopped, about 25 minutes before the end of the movie, and repeat tries could not get past that point. I then checked the file on the computer, with VLC, to make sure that the file went all the way to the end of the movie, and indeed it did. Now I could have then tried the file on one of the other player boxes I have here, like the Nvidia Shield, but instead I decided to AVS it into DVD format. AVS advised to leave the file as PAL, so I did. I chose HCenc (1-pass, this time) over FFMPEG, because I thought it was supposed to be the better encoder. I went with 4:3, because I thought that must be the original AR. The end result was unsatisfactory. First, the PQ is not as sharp as it was on viewing the source file, nor as sharp as I think it ought to be. It also came out with a semi-letterboxed look, in which a bit of the top and bottom got cropped off. Not good with the top of people's heads ! (It's like the 4:3 AR setting for this job got ignored ?) I'd like to watch the remainder of the movie, to best advantage, but I'm going to toss this not very good processing and try HCenc 2-pass, or finally go back to FFMPeg, if there is not a significant improvement. What wrong turns have I been taking here, if any ?Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Once again, you and I seem to be in sync, Seeker47.
Just last week, I encountered a similar problem with some PAL .avi files of an old UK tv series I'd never got around to watching til now. Of the eight episode season, five would stop dead and revert to player main screen somewhere between 15-25 mins into the hour when viewed on a media player or BD player (via data disc or USB, same issue). VLC was able to play the files all the way thru but some other PC players could not.
On a hunch, I loaded the avi files onto an old Mac Mini running an old version of MKVtools (MKVToolNix nowadays). Used the basic settings (passthru video, audio recode to AAC) to convert the files from avi to mp4, and the timeout problem was cured in the remuxed mp4s. I did not notice any significant degradation in quality or shift in aspect ratio. Perhaps you could try this workaround with your files?Last edited by orsetto; 29th May 2020 at 16:02.
Thanks orsetto, and Yes, I could try that. I went the AVS route because that had worked for me many times in the past. Maybe I was just guessing those times also, but those (pretty standard) guesses happened to pan out.
When I did the redo with HC 2-pass, the sharpness issue largely went away, and the degree of cropping was not as bad, even tolerable if not optimal, but then another problem crept in: from approx. that 1 hr. 6 min. point of the playback glitch onward, proper sync on the subtitles was lost. I'm thinking it may all come down to some defect in the source -- which is hardly uncommon for these downloaded files -- but then that's a guess too. That said, I also have to note that I encounter problems like these only rarely: generally the playback is fine.
I will look for the log file, and try to post it here.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
This timeout problem with certain AVI files was a new one to me, the reason I tried remuxing to MP4 with MKVToolnix was this trick usually worked for me when I encountered other file anomalies. Around 20% of such source files will not load properly in DVD authoring apps like DVDflick or AVS2DVD: I get an alert to the effect "file does not have a viable video track so it will not be loaded: this usually means the file is damaged or corrupted". In most cases, having MKVToolnix remux the file (passthru video with just a slight audio modification) cures the issue and DVD apps will then recognize it. In rare cases, I need to do a full lossy A+V recode of the file to another format in Handbrake, or strip the audio track out with Avanti-GUI (shell for AVIsynth/FFMPEG), delete the original track in the DVD app and substitute the stripped corrected audio.
I wouldn't even bother with DVD authoring anymore, except my elderly father enjoys a lot of arcane foreign stuff that I need to make compatible with his standalone DVD player. It took me five years to wean him from VHS to DVD, teaching him to operate a media player or to play USB or data discs thru a BluRay unit would be much harder than me just converting to DVD Video for him. -
Perhaps similar to your procedure with MKVToolnix (?), I must have 5 or 6 different video format conversion apps, such as the Digiarty WinX HD one. Another easy 'Go To' method I've resorted to when necessary is to use one of those. With some of these source files, it may be that the index is hosed ? (Not being able to FFwd. or Rewind it, or if you get freezes or time jumps could be a telltale sign of that ? And when you convert it to another format, or "AVS" it into the DVD format's straight-up MPG / VOBs, it seems to get re-indexed in the process ? Just a theory . . . ) More often than not, I find that the conversion has not deteriorated enough in PQ to pose a serious problem. But maybe that can play havoc with the timing on subs. When it comes to items that are out of print and plenty difficult to obtain at all, beggars can't be choosers.
Sure, it would be preferable if I actually knew what I was doing on a tech level, but often you simply don't have the time or the energy to make a serious project of something, and any expedient solution that more or less works is the one you reach for.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 13:39 -
TEncoder 4.0.0 - Multithreaded GUI for FFMpeg and Mencoder (Support thread)
By ozok in forum Video ConversionReplies: 104Last Post: 4th Jun 2014, 11:10 -
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 6Last Post: 8th Jan 2013, 04:53 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 21:37 -
Start product support thread?
By midders in forum FeedbackReplies: 2Last Post: 4th Aug 2009, 15:15
