Hey!
I've encoded 4 videos using autoGK. They are .avi files, and I am trying to edit them in Premiere. When I drag them over to the sequence window, it gives me that message and won't load them. I've tried it with other .avi files I have, and it gave me the same message. The files I encoded have 384 kb/s stereo CBR 48000 Hz mpeg audio. The other ones I tried have 128 kb/s stereo VBR 48000 Hz mp3 audio. I get the same message, and can't open stuff in premiere. Anyone know what's going on with that? Thanks!
-Justin
ARe you converting to xvid avi? Then it looks very similiar to https://forum.videohelp.com/topic323224.html?highlight=unsupported%20audio%20rate%20premiere
Convert to another video format like dv avi instead.
Audio goes progressively out of sync. Calculate the "rate of change"?
By rayden54 in forum AudioReplies: 1Last Post: 26th Sep 2010, 07:48 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
BR structured image file is found as "unsupported"
By besthost in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Jun 2009, 02:06 -
Premiere Pro "direct stream copy"?
By Colmino in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 10:31 -
Blurred or "glowing" highlights in Premiere PRo
By wturner in forum EditingReplies: 7Last Post: 27th Sep 2007, 02:06
