I have an Adobe Photoshop file (PSD) I added that into Adobe Premier timeline along with a 27 second audio track . I exported the video at 24FPS using lagarith video codec and i exported another video using the same file but at 29.97 FPS.
I Played these files in my media player and both the 24 and 29.97 files play at the correct length of time
I then added the files to a project i was working on in Adobe Premier separately. The video in the project was at 29.97 FPS. I added the 29.97 and exported a video at 29.97 and made another video , added the 24 and exported it at 24.
The end result is that neither of them would play for the correct time.
The first video which was originally a psd file will only play for, not even a second, it flashes on the screen and goes right into the next video.
Any ideas how to correct the problem.
Results 1 to 1 of 1
AnonymousGuest
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 14:53 -
DGIndex creates .ac3 file double in length (timewise) of video
By karpodiem in forum Video ConversionReplies: 1Last Post: 20th Jul 2011, 16:51 -
ReelDVD 2.5 crashes when I import PSD file for a menu
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2010, 08:21 -
Way to tell length of a video file from command line down to milisecond?
By Mountain Man in forum LinuxReplies: 2Last Post: 15th Dec 2009, 10:54 -
Video file time length is incorrect after converting to M2TS
By Alterego in forum Video ConversionReplies: 0Last Post: 18th Oct 2008, 11:54
