Does anyone know how to do the following with Zoom Player? I wanna take a video i made, and have it play right in the middle of the tv screen (after converting it to DVD and playing it in standalone DVD player), kinda like a letterbox type of video. I figure that if it's in the middle of the screen, the small size of the video, while still big enough to watch, will look a lot better. If i just convert it normally, the correct aspect ratio will be used and the video will stretch, and make things look worse.
Any help would be appreciated! thanks!
	You just zoom out with zoom player. If you want want to convert to a dvd-video you add black borders around the image so it doesn't stretch out to 720x576/480 or just use a lower video resolution like 352x288/240 that is supported in a dvd-video. Use a good dvd/mpg converter where you can adjust that like tmpgenc xpress.
  Best way to change aspect ratio....By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 11:33
  Aspect Ratio ChangeBy VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 12:01
  How to change aspect ratio?By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 11:49
  Aspect ratio and a zoom useBy LCSHG in forum DVD & Blu-ray RecordersReplies: 28Last Post: 10th Nov 2007, 12:01
  change aspect ratioBy zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 10:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
