I have been slowly ripping my dvd collection to divx so I can stream it across my home network. To do this I have been using the following application chain
DVDFabDecrypter > pgc.net > avi.net
Up till now I have had no problems with this arrangement, until now. Now with the final divx the sound is out of sync with the video. I have checked the ripped vob files by playing them in divx player and they are in sync, at both the dvdfab and pgc stages.
Is there a way of fixing this?
Results 1 to 10 of 10
Does it happen with all dvds now? or have you just tried one?
Haveyou installed any other video software or codecs lately? -
Just this one dvd But I haven't tried another. I have installed autogk to try that but I just cause system problems. Is there a way to resync the audio on the final divx?
I have also tried installing the apps on a new pc and it still happend. I think that I need to try ripping another dvd. But I would like to solve the problem for this one in case it happens again.
Thanks for your quick reply -
Open the avi file in media player classic, and use the + and - keys on the number pad to shift the dely until you have the audio in sync. Note the delay.
Open the file in virtualdubmod and click on Streams -> Stream List. Right-click on the audio track and click on Interleaving. Enter the delay you determined through MPC into the box in the lower half of the dialogue. Click OK.
Make sure that both video and audio are set to Direct Stream Copy, and save a new avi file with audio in sync.Read my blog here.
Gunslinger,
Thanks I will try that. Will let you know how it goes.
Sound out of sync in Avidemux
By Lambert in forum EditingReplies: 21Last Post: 19th May 2010, 00:59 -
Out Of Sync sound in mpeg2
By JN in forum Video ConversionReplies: 2Last Post: 20th Nov 2009, 03:52 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
