Hello Gurus,
When a receiver does "HDMI passthrough" - does it matter if the input signal is in PAL or NTSC?
I.e. If my input signal is in NTSC (X-Box) going to my NTSC compatible TV ... BUT connected through my A/V receiver which is a PAL unit - then will the signal get scrambled? ... or will the signal just get "passed through" without any problems?
I don't understand how this signal passthrough happens and I don't want to waste a lot of money buying the wrong device(s).
Thanks in advance for any light you can shed on this topic,
Gausman
Good question that should be asked to manufacturer. The issue is 25/50 vs. 29.97/59.94 frame rates at HD since frame sizes are the same. Complicating factors may be HDCP encryption and sound stripping for the receiver-amp.
My understanding is only a few current receivers support HDCP encryption which will be required in the future for passing Blu-Ray or HD DVD video or stripping audio.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Need a DVD Recorder with HDMI passthrough
By mabus in forum DVD & Blu-ray RecordersReplies: 11Last Post: 31st Jan 2010, 15:37 -
Splitting DVI and HDMI signals. Veterans please check my setup
By anubis13 in forum ComputerReplies: 9Last Post: 21st Jan 2010, 16:14 -
PS3 Pal/Ntsc flavors over HDMI?
By tambur in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2008, 15:57 -
HDMI, NTSC, and Pal
By Big C in forum DVD & Blu-ray PlayersReplies: 14Last Post: 27th Jul 2007, 17:13 -
Yamaha DVD-C950 - Pal-to-NTSC Conversion over HDMI
By Big C in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2007, 13:18
