I have several old concerts from 1970's TV.
They were set up into VIDEO_TS folders, that can be burned and made a DVD with a menu.
The person who originally made these, designed these so that the 4 concerts could be burned together by moving the right numbered VTS_# files into the same folder with new VIDEO_TS* files (so concert 1 is in VTS_1, 2 is on VTS_2 and so on).
If you have the combo menu, it works brilliantly (I've tried this with a different set).
You get a front menu that lists the 3 concerts. Click on it, it takes you to the concerts custom menu, and so on.
However, for the current grouping, I don't have the combo menu.![]()
So, is it possible to make a new one? (a new master menu that leads to the Pre-existing sub menus)?
I've tried with Toast so far, just by making a menu and transplanting it, but the results have been less than whelming.
Could iDVD or Studio or something else do this? Is this something that just can't be done?
DVD Studio Pro could do this, however the assets would have
to be demuxed first back into .m2v and .aiff ( or .ac3) and then
a new menu could be built that has buttons that point to the different
concerts, which would be added to the timeline in their demuxed asset form.
You then could create a sub menu that then further breaks down
the assets into seperate concerts on their own seperate sub-menus
if you wish.
Toast 8 should allow you to pull the assets from their Video_TS folders
and then generate a new menu and build a new DVD. The menu
will be straightforward, making all the assets appear on one dvd
as sequential assets, without sub menus to only specific concerts.
Frobozz can speak more on this, but IIRC, that is all Toast 8 can do."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Could iDVD be used for this...making a DVD with dummy media files with the structure I want, then go in and repace the VTS_# files with the real ones after and use Toast to burn?
Is there somewhere (I'm sure there is on this site) something that talks about how the files work? as in...does the VIDEO-ts file say "when this area is clicked, go to VTS_1" or does it say "when this area is clicked, go to VTS_1 that does x, y, and z?" -
Originally Posted by Scav2003
For most of your functions you can use your tip (but take a look to your result with myDVDEdit)
(so not very easy but possible, the best way is to extract all the streams -and menus- and make a new authoring with them: DVDSP or ... even MovieGate)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
Adding Menu to Existing DVD
By HamishT in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2011, 15:23 -
To edit an existing menu, or make a new one ?
By Chainsaw_1 in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2010, 16:50 -
make menu for existing vobs?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jul 2009, 12:34 -
editng existing menu on DVD-R
By noki in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2008, 11:18 -
Add menu to existing DVD?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd May 2008, 17:56
