I was wondering how to burn the vob, iso ect files after they're made. I had a .wmv and I used easy wmv convert and it made the vob files and everything ok but I don't know how to burn em. It's been a while since I made a back up and I remember something about after I made the vob files I could just burn 'em using nero express but that doesn't seem to work for some reason. So I put 'em in nero vision but it seems that it's taking forever and a day to do it becasue it is converting it AGAIN to ntsc and all that kinda stuff but that stuff was done when I converted it from wmv to the vob files so what's the prob? Why can't I just straight burn the vob iso and all those files to a dvd? Thanks
Nero has a bad habit of wanting to re-encode everything you put into it, even DVD compliant video.
You may be able to turn that off, but I would just use a real authoring program instead. If you want a freeware authoring program, try GUI for dvdauthor. Or payware, TMPGEnc DVD Author is easy to use.
so there's no way to just take the vob files and stuff i have and burn 'em to a standalone dvd compliant video? i have a slow *ss computer and it took me like 3 hours to get the vob files! dang i hate to have to re do it!
oh yeah does that gui for dvdauthor burn too? i obviously already have something to author it, it's the burnign part im having a prob with, so many progs wanna do both but hardly any seem to want to just burn, that's really all i need, just take the vob iso ect files i have and burn 'em.
Sorry, I misread your original post. You already have the authored files.
You don't need a authoring program if they were processed correctly, just a burning program.
So using Nero Burning ROM, just select 'DVD-Video' and put the contents of your VIDEO_TS folder into the red VIDEO_TS folder Nero shows. If they are DVD compliant, they don't need to be re-encoded.
Or for freeware and even easier, use ImgBurn. Select 'Build' mode and point it to your VIDEO_TS folder. It will burn the files to a DVD. ImgBurn is recommended over Nero most times for just burning.
To see if you have a DVD compliant file, you can look to 'WHAT IS' DVD on the upper left on this page. That will give you info on the DVD format and specification. -
thanks i'll try that cuz as much as i USED to like nero, lately it's been SUCKING for some reason, they seem to get crapier as they 'progress'
hey that worked great and took less than 15 mins to burn compared to stupid nero reauthoring and taking like 5 hours! hah
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
About to author, what BG Music
By nirbhayn in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2009, 21:14 -
how to author a CD?
By michcio in forum Authoring (VCD/SVCD)Replies: 4Last Post: 2nd Sep 2008, 13:06 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Author without re-encoding?
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 13Last Post: 24th Jul 2008, 10:21
