I'm after a device that you can connect to your TV or DVD-Recorder
'That Alllow's you to change the picture-setting's to thing's such as
(Postcard/ Letterbox/ Widescreen/ Cropped)
The similar thing's that you get to chose from with certian-DVD's for example...
'Is there any such device available to purchase off Ebay ?
This is normally a function of the TV or DVD player.
Which models of each are you using?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Well The DVD-recorder i have, has the option to change the picture but doesn't do anything..Originally Posted by edDV
It is a "NEC NDH-80" The TV i have is from 2001,
Anyway, i know a person who has a tv and it has the option of changing the picture to 'Letterbox, Wide Or Zoom..
But when you TurnOff the Tv it goes back to Default!
And this Same person has 'Cable-Tv, & they get to choose which Picture-setting they want (Cropped As the Default-setting) followed by: Postcard/ Letterbox/ Widescreen...
'With the cable-Programs that are Originally in Letterbox, If you change that to 'Widescreen' you get the whole-thing!!
I am after a device that does the silimlar thing's,
But do not want Cable-tv -
The NEC NDH-80 should have settings for 4:3 or 16:9 ... For a 4:3 TV set select 4:3.
It will also have a setting for 16:9 (wide), pan/scan or letterbox. Pan scan gets you the center 4:3 of a 16:9. Letterbox gets you letterbox.Recommends: Kiva.org - Loans that change lives.
Like i said, it doesn't do anything!!,Originally Posted by edDV
Also
with certain Dvd's You are able to change the Picture-Settings, But it doesn't do anything when i do it...!
I've tried these DVD's that say they are capable of & have Tested them on Various- Tv's & Players
And the picture does not change ?? -
Don't know. My players respond to settings.Originally Posted by grom
Is there a wireless device to control a cable box remotely and send picture
By MrBiggZ in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2012, 19:18 -
How to change the IE 7 default setting of webpage Save As?
By coody in forum ComputerReplies: 0Last Post: 17th Aug 2009, 13:15 -
How do you change the default View Setting for a folder's contents in Windo
By videopoo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2009, 17:41 -
Change camera setting with VFW
By Vahidzj in forum ProgrammingReplies: 0Last Post: 23rd Jun 2008, 08:52 -
Tevion TDVD08 DVD Player - Picture problem when 5.1 ch setting used
By alfredspacey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Jun 2008, 01:03
