I have Win Vista and im struggling to find a good program that will convert DVD/ISO to Divx/Xvid Can anyone help ?
Results 1 to 14 of 14
AVI.NET has never failed me.
It produces DivX/XviD files that are compatible with standalone DivX/DVD players
And runs perfectly well on Windows Vista
https://www.videohelp.com/tools/avi.NET
http://www.clonead.co.uk/
Stephan -
Daemon Tools to mount ISO
DVDDecrypter in IFO mode to extract movie to single VOB.
DGIndex + AviSynth for filtering (optional)
VirtualDUbMPEG2 or VirtualDubMod to convert to Divx or Xvid AVI. -
How about converting from the Divx/Xvid to standard DVD so it can play on any DVD player? What is the easy and reliable program can convert from either format?
coody: convertxtodvd. BUt it has NOTHING to do with dvd to divx/xvid. Make a new topic if you want more information.
Try these threads:Originally Posted by coodyআমি বাংলায় গান গাই
I'd do this.Originally Posted by jagabo
Probably is not needed. VirtualDub has filters too, if you did want to filter. Preference, I guess.Originally Posted by jagaboWant my help? Ask here! (not via PM!)
Hello lordsmurfOriginally Posted by lordsmurf
I tried DVD Decrypter in IFO mode, but the DVD has multiple VTS folders and hence multiple PGCs. So how could it be tackled?আমি বাংলায় গান গাই -
That usually indicates a TV series with serveral episodes. Extract each episode in IFO mode with no file splitting. That will give you one VOB per episode.
Has anyone tried AviDemux 2.4? I'm running it now but I'm
curious if anyone has had good luck with it. I just got done messing
with HandBrake and I thought it might be a winner... until it crapped
out 1/2 way through a DVD telling me it failed reading the HD. Uh,
that's uninstalled!
Other than VirtualDub and the others mentioned already in this
thread, any other good Windows freewares? I"ve used StaxRip in the
past but the UI is just too counterintuitive for me(and I could
never figure out how to get it to process audio to other than mp3)
Program for converting DVD to Xvid with 3 audio tracks ?
By Noahtuck in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 00:17 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 05:39 -
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 10:06 -
Converting Dual Layer DVD to Divx/Xvid
By Snorph in forum DVD RippingReplies: 8Last Post: 15th Mar 2008, 16:37 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19
