Can any body help i have been using the Sony DVD Recorder now for aprox 3 Years and its appears to be fine and i ma using Datasafe DVD RW2X But seem to get what i can only describe as Motion trail for example when a head moves it appears that there is a trail created by the move until the picture catches up which leaves a blur.
Does any body know how i can get rid of this.
Many Thanks
Have you been drinking? no well, Sony's noise reduction (NR) options cause motion blurring especially at the higher settings, I don't know if you've played with the settings much. Its in the manual, but I think its Tools>picture record settings>NR and set it to 0. If yours is set at the max. +3 then that will be the problem. It's not good NR so best left off.
If thats not the problem then - are you using HQ/SP setting anything above may cause bluring esp. at the longest rec. setting. If not sounds like a rec. error try different disks at HQ to rule it out.
Sony Z5 slow motion
By savadepa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Apr 2011, 09:09 -
Slow motion problem in Sony Vegas 9
By plisb in forum EditingReplies: 4Last Post: 16th Dec 2009, 09:32 -
In used Nero Trail Can not hear the comnversations for Music
By frankduffey in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2009, 09:41 -
alternatives to Sony picture motion browser
By triassicpark1 in forum Video ConversionReplies: 0Last Post: 18th Aug 2008, 10:46 -
Sony Vegas 8 - Track Motion Preset saving???
By sdsumike619 in forum EditingReplies: 2Last Post: 4th May 2008, 01:47
