Thank you for taking the time to read my post.
Basically, I want to be able to edit the audio of a DVD.
I will probably have to rip it off the DVD and then I'll be able to edit it; the thing is, I want to be able to put the audio back into the Audio_TS file and be able to burn the movie onto a DVD. Or something like that. Is this possible?
The reason I want to do this is because I want to show R-rated movies at a high school, and I was thinking that editting out the profanity would make parents more comfortable with their kids seeing a R-rated movie.
Is the method above feasible, or is the only option I have to rip the audio, edit it however I want, then while playing the movie on mute play the audio on a different medium, like a boombox?
Thanks for your help!
The audio was never in the Audio_TS folder, it is in the VOB files, along with the video, menus and sub-pictures.
It is feasible, however you are better off just ripping the video and audio, editing the audio, then authoring a new disc with simple or no menus.
If you decide to do this, make sure you do not cut the audio, just mute the sections you want to get rid of. Cutting the audio is a sure way to introduce audio sync problems.
Finally, consider carefully the amount of work involved (this isn't a trivial task), and also if the profanity is the only reason the movie is rated R. I suspect that there will be a lot more than just language that the parents would object to.Read my blog here.
Also, as you're doing this for a school, be aware that you will be making a copy of a DVD, which may be illegal depending on your local laws. For home use, no one cares, but the school may get into trouble, and you would be the fall guy.
Don't WalMart or Blockbuster sell censored versions of movies? -
Thanks for the replies!
AlanHK: Walmart and Blockbuster don't sell censored versions
Gunsl1nger: Advice taken.
Now, I have searched around forums for tuts but there are different versions and I don't want to obtain programs only to find that they don't fulfill my purposes adequately. Any suggestions on which programs to use?
Removing Swear Words From Movie
By poordamocles in forum EditingReplies: 9Last Post: 9th Aug 2018, 16:49 -
removing subtitles (foreign language) from a downloaded movie
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 22:40 -
Removing audio tracks from DVD
By txl in forum Authoring (DVD)Replies: 2Last Post: 26th Nov 2009, 11:06 -
removing one audio track from an avi movie file
By srckaimal in forum AudioReplies: 1Last Post: 4th Nov 2009, 19:28 -
Removing certain audio streams/subtitles from a DVD
By SiM99 in forum DVD RippingReplies: 18Last Post: 7th Feb 2009, 01:46
