    Dec 2006
    Singapore
    I was playing a video with VLC. But the video keeps lagging i.e. it also stops at a scene and after a few secs later go on to the next scene. Is this something with with my computer? or is it the player? I am quite sure the video is ok since other ppl who d/l it have no such complain.
    USA
    Depending on the video format and based on your listed computer specs, I would say it's your computer. Some formats are very CPU intensive. And VLC can use a lot of resources. Some highly compressed formats need a fair amount of CPU power. H.264 playback is one example.
    You could drop one of the videos into Gspot 2.70 and post a screenshot of the results here and we may be able to give you better advice. One guide for that: https://forum.videohelp.com/topic271697.html
    Dec 2006
    Singapore
    here is the screen shot. iguess its my computer then...
    Apr 2004
    Miskatonic U
    You simply do not enough CPU or memory to play H264 at resolutions above 320 x 240. If your computer details are correct, what you have is almost a museum piece (although not the slowest machine here. Someone else was trying to encode on a 667mHz system).
    Time to upgrade.
    Read my blog here.
    Aug 2006
    I bet that was turtle slow
    Dec 2006
    Singapore
    haha..yep..i guess so too..thanks all for the advice!
