I'm trying to create my first DVD using SVCD2DVD. I've added the asset, created a simple menu, and using the "Create your DVD..." icon, selected "Make DVD...".
Proceeding slowly I left "NO, don't burn" selected and the computer went off for a long time processing my movie.
When it finished, I wanted to go to the next step and burn it but it appears there's no easy way to get there. What I was expecting was a step in "Create your DVD..." for "burn the stuff I just spent substantial time processing".
Now that I've spent some time in this forum I've figured out how to do the burn but not before I started over selecting "Yes, Burn my DVD". The computer is still processing...
I think SVCD2DVD should provide a more obvious way to do this.
Thanks,
Brad
It is obvious - you select it at the beginning of your project.
If you already have burning software, it's easy to use that to burn the VIDEO_TS created by S2D to a DVD. Had you asked here, we could have easily shown you how. Redoing your entire project was totally unnecessary. Even if you restarted your project, the encoding step was unnecessary the next time through.
If you have ImgBurn, ChrissyBoy has "ImgBurn DVD-Video Shell Ext" available on his front page at svcd2dvd.com which will allow you to quickly burn any VIDEO_TS folder.
So there are easier ways to get there, you just needed to ask.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thanks for the response. I think I now understand how to continue with the burning process (RTFFF
I'd like to understand what you mean by this. I'm not sure I understand how to skip the encoding step. Can you explain or point me somewhere?Originally Posted by Jikchung
Regards,
Brad -
The encoding step creates a new file from each asset and appends the filename with "S2D". You simply replace the original assets with the corresponding S2D files (provided you haven't set SVCD2DVD to automatically delete them) and the encoding step is skipped. S2D will see the files are already compliant and proceed to the authoring step.
If you need to burn a DVD post creation, the ImgBurn DVD-Video Shell Ext is really the best way though.Dwight
- Herm Albright
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
