Hi
Tried posting this in the newbie forum but received no replies.
Thought I would try here.
I am attempting my first video conversion using ffmpeg on Ubuntu Feisty.
Tried converting a wmv to avi in the hopes of producing a divx/xvid file.
I converted but the output video is very jumpy. Input video was fine.
I am very new to video formats and the technical language of it all so simple suggestions would help me.
This is the command and output of what I tried.
ffmpeg -i inputfile.wmv -ab 128 -b 1200 outputfile.avi
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-gpl --enable-pp --enable-pthreads --enable-vorbis --enable-libogg --enable-a52 --enable-dts --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
libavutil version: 0d.49.0.0
libavcodec version: 0d.51.11.0
libavformat version: 0d.50.5.0
built on Jan 28 2007 22:48:38, gcc: 4.1.2 20070106 (prerelease) (Ubuntu 4.1.1-21ubuntu7)
[wmv3 @ 0xb7ec2508]Header: 4D291A01
Seems that stream 0 comes from film source: 1000.00 (1000/1) -> 1.17 (7/6)
Input #0, asf, from 'inputfile.wmv':
Duration: 01:38:43.6, start: 5.000000, bitrate: 1262 kb/s
Stream #0.0: Video: wmv3, yuv420p, 320x240, 1.17 fps(r)
Stream #0.1: Audio: wmav2, 48000 Hz, stereo, 128 kb/s
Output #0, avi, to 'outputfile.avi':
Stream #0.0: Video: mpeg4, yuv420p, 320x240, q=2-31, 1200 kb/s, 1.17 fps(c)
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 6912 q=2.0 Lsize= 139226kB time=5923.7 bitrate= 192.5kbits/s
video:40709kB audio:92558kB global headers:0kB muxing overhead 4.472184%
Any assistance/explanations would be greatly appreciated.
Famine99
Your output file isn't going to be divx/xvid with that syntax. Look up the "-vcodec" parameter to specify the compression to use.
yes framerate.
1.17 fps doesn't sound right.
ffmpeg often can't detect framerate with certain containers,
and you'll need to determine it yourself and set with -r
You might want to update your ffmpeg build first as what you are using is ancient.
with output set to .avi,
video encoding defaults to mpeg4, which is fine.
just slap aon for compatibillity.Code:-vtag DX50
i wouldn't think mp2 audio is what you want.
probably want mp3
(recent build syntax, old builds are -acodec mp3)Code:-acodec libmp3lame
Speaking of syntax,
newer builds require bitrate be set like so:
also default mpeg4 settings are crap.Code:-b 1200k -ab 128k
at least add
glCode:-mbd 2 -flags trell
Thank you all for the replies.
The ffmpeg package was updated right before I did this so the Ubuntu/Debian package must be old. I will download and install the latest from the project page.
I will research and try all of the settings that have been suggested but I have one further question.
How do I determine the correct frame rate of the input file? If ffmpeg can't seem to accurately detect it is there another tool I should use?
Once again thanks for your help.
Famine -
Not really. You can try ffmpeg's first cousin, Mencoder, but as mentioned above, a more recent version of ffmpeg will work for your purposes.
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 22:40 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 14:18 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 19:15 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 08:32 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04
