    Apr 2007
    Canada
    hi guys i wanna make episode dvd disk of some xvids i got.. i have cce sp for encoder and i seen i here ppl say encode each episode sperately then join them to together at author stage.. i wanna fit 4 episodes per dvd disk but i'm not sure how to go about setting the right video bitrate for each xvid.. because when i use bitrate calculator i don't want the one episode to fill the dvd.. so i'm lost
  2. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    Use vcalc and set the runtime of the 4 episodes combined, and factor in the audio bitrate you will use (192k prob fine), and any overhead for menus you want to make and so on.
    Apr 2007
    Canada
    thx it worked out
