I dont know if thisis the right place to post this or if anyone here can help but here goes. I rip thru dvd shrink and it automatically opens nero and burns to a dvr without me having to open nero and drag the files over. Well for some reason i began getting an error last week. I uninstalled and reinstalled both nero and dvd shrink but the problem is still occuring. It happens after the movie is ripped and the drive opens I install a blank dvr and this error come up. If anyone can point me in the right direction id really appreciate it. Im still able to burn but i have to manuall open nero and drag the files over. Here is the error
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 4/2/2003 7:13:44 AM
Nero API version: 6.0.0.0
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <DVDRW IDE 16X> Version: A089 - HA 0 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
CdRomPeripheral : DVDRW IDE 16X atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD300AB-00BVA0 atapi Port 0 ID 1 DMA: On
DiskPeripheral : HDS722540VLSA80 atapi Port 1 ID 0 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1270MB (1300556kB)
Free physical memory: 908MB (930068kB)
Memory in use : 28 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.10.2007
NeroAPI
2:51:26 PM #1 Phase 112 File APIProgress.cpp, Line 232
DVD-Video files reallocation started
2:51:26 PM #2 Phase 114 File APIProgress.cpp, Line 232
DVD-Video files reallocation completed (no file modified)
2:51:26 PM #3 Phase 111 File APIProgress.cpp, Line 232
DVD-Video files sorted
2:51:26 PM #4 Text 0 File Reader.cpp, Line 118
Reader running
2:51:26 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
2:51:26 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3814
2:51:26 PM #7 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-At-Once, using DVD media
2:52:03 PM #8 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2286149 (508:01.74)
2:52:03 PM #9 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
2:52:03 PM #10 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: DVDRW IDE 16X, Media type: DVD-R
Disc Manufacturer: RITEKF - 1
Disc Application Code: 64, Disc Physical Code: 193
2:52:03 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2286150 (2286150) = #2286150/508:2.0
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286150 blocks [DVDRW IDE 16X ]
2:52:03 PM #12 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to DVDRW IDE 16X on a DVD-R media
2:52:03 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder DVDRW IDE 16X for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 387375104
2:52:03 PM #14 Phase 24 File APIProgress.cpp, Line 232
Caching of files started
2:52:03 PM #15 Phase 25 File APIProgress.cpp, Line 232
Caching of files completed
2:52:03 PM #16 Phase 36 File APIProgress.cpp, Line 232
Burn process started at 16.1x (22,218 KB/s)
2:52:03 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
2:52:03 PM #18 SCSI -1080 File Cdrdrv.cpp, Line 1151
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x0B456000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x3A 0x00
2:52:03 PM #19 CDR -1066 File ThreadedTransferInterface.cpp, Line 1482
Invalid field in command
2:52:03 PM #20 TRANSFER -35 File ThreadedTransferInterface.cpp, Line 1482
Invalid track info
2:52:03 PM #21 Phase 38 File APIProgress.cpp, Line 232
Burn process failed at 16.1x (22,218 KB/s)
2:52:04 PM #22 SCSI -1080 File Cdrdrv.cpp, Line 1151
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x1B 0x01 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2:52:04 PM #23 CDR -1080 File BurnCDUtils.cpp, Line 344
Disc not present
2:52:04 PM #24 SCSI -1080 File Cdrdrv.cpp, Line 1151
Sense Code: 0x3A
Sense Qual: 0x00
2:52:04 PM #25 CDR -1080 File BurnCDUtils.cpp, Line 344
Disc not present
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 10/28/2003 6:02:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I'd look into using imgburn - it's free, and burns better than Nero
Yes, I do have Nero - I just don't use it with Shrink.
Also: Slow down your burn speed a bit - you may be overloading the cache.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
How 2 burn 4GB VOB Compliant DVD: Shrink Error "Cannot find specified
By V12V12 in forum DVD RippingReplies: 11Last Post: 5th Aug 2013, 11:42 -
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 14:33 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
