Hello,
I am currently in the process of converting some pal dvds to ntsc. I'm starting on disc 1 of 6 so it's gonna take a while. anyway I successfully used cce to convert the video and I'm left with my m2v and my ac3 that was demuxed from the original. I have yet to test this out to see if it's in sync. Anyway I was able to use numenu for you successfully, but after it processed the menus, I've got a bunch of folder with files and stuff. What exactly do I do now? Could I use these files in tmpgenc dvd author? I have menu edit and some ifo programs but I've never converted a menu before so I'm totally lost. Thanks
So far I've tried out a few things:
In menuedit I opened up the new menu vob (the ntsc one) and tried to somehow import the subpic bitmap that newmenu4u created but it only accepts mbl files. I also tried to open up the original vob and save the buttons as a mbl and try those,but due to frame size they are not in the right spot. For the life of me I can't get menuedit to make proper buttons. once I create one it won't let me move it where I want and if I do change the values the top and bottom value won't let me edit them after that. So I've got the ntsc menu and the correct sob pics but in bitmap form,how do I apply these together now? thanks
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
