Are the Pioneer 18 x and Philips 20 x drives good? Which is better or you know the other best DVD drive?![]()
The best SATA internal dvd burner right now is the SAMSUNG S203B 20x drive. If you have SATA ports on your mobo take this drive into consideration. But if you don't then my suggestion would be to get the PIONEER 112 or LG62N, LG H62L or even the SAMSUNG 183L. The "L's" mean the drives have LIGHTSCRIBE TECHNOLOGY.
You could get a PCI SATA CONTROLLER CARD if you want to get the SATA SAMSUNG S203B dvd burner. Check out the review for that dvd burner at Cdfreaks.com.
I would stay away from the PHILIPS drives. They're probably rebadged LITEON's.
Looking for best 2tb internal drive and dock
By neworldman in forum ComputerReplies: 3Last Post: 25th Nov 2010, 04:14 -
MPC : Internal Subtitle render versus ffdshow or directvobsub
By uart in forum SubtitleReplies: 8Last Post: 20th Jul 2010, 15:14 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 13:17 -
internal hard drive
By LFC 1304 in forum ComputerReplies: 3Last Post: 4th Jun 2007, 11:37 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 08:48
