I have two AVI files and I want to join them together using svcd2dvd.
I have added both files and it converts them to fit onto a 4.7 GB DVD no problem. The problem arises when I play the DVD in a DVD player. On other programs such as DVD Santa and convert x to DVD there is a slight pause (similar to the pause you sometimes get with dual layer films) and it resumes playing the second converted AVI file almost seamlessly.
With svcd2dvd it freezes and I have to press the next chapter button on my DVD player to resume playing. I cannot join the AVI's together because they have different audio rates.
So is there anyway to join the two converted AVI files together so that there is no pause at all or is there a setting on svcd2dvd so that there is only a slight pause instead of the disc freezing completely. The setting I am using currently is quick DVD.
Post your log for the run. If you are putting both files in the same VTS it should run seamlessly.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
You could try the "Merge Titles" option in the settings...
heres a way not the quickiest but it works for me you will end up
with a avi containing ac3 2 channel audio
you will need these all free
ffmpeggui
VirtualDubMod
load the first avi into ffmpeg gui
it will extract the audio then change the audio setting to
format ac3
bitrate your choice
sampling rate 48000
audio channels 2
then browse to where you want to save it and give it a name then click save button
now just click the convert button
when done do the same with the second avi
now load up virtualdubmod load the first avi
if you get the error pop up to change the header click no
now click video/direct stream copy
now click streams/streams list
when the available streams window appears click disable button
bottom right then ok button
now click file/save as
give it a name then press save button
when finished do this with the second avi
now you should now have 2 video and 2 audio only files
now you load the first video in click video/direct stream copy
now when you click streams/streams list click add button
and load the converted audio file from ffmpeg gui you made earlier and press ok
now goto file/append segment
when new window appears choose the second avi video only file and click open
then click streams/streams list
and add your second audio file and press ok
now save as your new file
this then should load into svcd2dvd -
Ha! I did and it is seamless, thank you!Originally Posted by ChrissyBoy
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 07:58 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 09:40 -
Putting time code on AVI files
By snap25 in forum MacReplies: 1Last Post: 24th Nov 2007, 22:15 -
Putting downlaoded files on DVD
By sofa in forum Video ConversionReplies: 1Last Post: 17th Nov 2007, 23:51 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57
