Hi, I just bought a new Pioneer drive, my old 108 drive died on me last week. After installing and updating the firmware to 1.22, I proceed to make a data DVD, it finishes verifying perfectly, I even verified it using nero cd/dvd speed tool. when i tried to copy all the files to a folder in the hard drive when it was almost at 50% it said it could not copy the file specified because the path was not found, when I check My computer the drive was not listed, I checked Device manager and it wasn't there either. I can see the drive is getting power because I can eject the dvd and place another one in.
any pointers?
thanks!
I take it you have the PIONEER 112D drive. Make sure you're using a 80 wire ide cable with the drive or it will not work correctly. This has been documented in their manual. Buy a new 80 wire ide cable and make sure you have it set correctly to master or slave setting.
Yes im using an 80 Wire cable and I have it at slave setting, it worked and then it just dissapeared from the devices.
is it a new 80 wire ide cable or the one that you were using with the PIONEER 108? if it's the same ide cable i still would suggest buying a new one.
try setting the drive to master. some at cdfreaks say using the PIONEER in the master setting is better. -
108 worked with 40wire ok, any since the 109 REQUIRES 80 wire!!!!!!!
*** Now that you have read me, do some other things. ***
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
Pioneer 112 or 112D?
By blacktooth in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 18:09 -
Pioneer 112D to 112L question
By Trailryder in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 13:26 -
Pioneer 112D problems
By Xande in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th May 2007, 22:13
