I have searched and found lots of similar posts going back over a year but cannot see the cure.
i installed the VOB2MPG and it worked perfectly the first time but now no matter what VOBs i use or where they are located or where i put the output file or even what DVD i use i just can not get it to work, all i get is "Finished Processing 0 VOBSETS" the first time it happened it did process one vob not the 3 others in the folder, just the smallest one.
Please did anyone solve this, i would really love to use the app.
Many Thanks for all help
Can you post your log file?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Should be in the 'logs' folder where you installed the program.
Dwight
- Herm Albright
Yep, strange. There should be something there since it worked before.
Here is where it should be:
Dwight
- Herm Albright
Multiple title-sets share the same vob's
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 17th Oct 2010, 19:52 -
VOB2MPG PRO viewing .vob problem
By nautalis in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Oct 2010, 13:26 -
Problem to convert .VOB to .MPG with vob2mpg
By akakiami in forum Authoring (DVD)Replies: 14Last Post: 17th Mar 2009, 08:51 -
Multiple VOB sets onto 1 DVD?
By bcemail in forum Authoring (DVD)Replies: 3Last Post: 6th Apr 2008, 18:09 -
vob2mpg does not work
By darkelf in forum DVD RippingReplies: 4Last Post: 16th May 2007, 12:17
