I replaced an hp cd writer i9300 with an hp dvd writer 1040i. I moved the i9300 to another pc. When I tried doing an "hp simple backup" and select full system backup or custom backup the following error message is displayed: program error sbwin32.exe has generated errors and will be closed by windows. I get this message on both pc's.
I found the problem with the i9300 getting this message on the pc it was moved to was the power cord was disconnected. After connecting the hp simple backup worked.
On the system with the 1040i I tried loading the nero software supplied with the drive and I never get a menu. I tried the nero disk on the system with the i9300 and it works OK. Also the 1040i will read other disks and display a menu.
I sent a problem report to HP a week ago and have not received a response. I also tried calling the hp support line and got a recording indicating no phone support for the 1040i. Anybody have any idea? Thanks!
	Uninstall Nero and the other backup software. Reboot and then install whichever software you are wanting to use. Most likely you are having multiple issues. First, the original software you are using, likely noticed the drive change. Some burning software (like Alcohol 120% for instance), allows you to rescan the system bus after installing/changing drives so that the software can identify all drives on the system. If the software doesn't allow you to rescan, then a uninstall/reinstall will usually solve the problem as a system scan is part of the installation. Google is your Friend
	I reinstalled the i9300 in the original system. Still getting the sbwin.exe error message. Tried removing and reinstalling the simple backup software. This did not resolve the problem. The simple backup software comes on the "hp cd-writer plus" cd. There are 3 other programs on that disk. Installed all the programs on the disk. This resolved the problem.
 I am waiting on a replacement dvd writer. When it arrives I will try uninstalling, rebooting and reinstalling the hp cd-writer plus software. I'll post an update.
	Don't know if you got your issue fixed, but just in case you didn't. I had the exact same problem and discovered that it was the IDE cable. I change it to a ATA 66 and no it works great.
	My first couple of CD burners were HP's. I seem to recall having issues with them if I didn't install the whole software suite (it's been quite awhile, so I don't remember all of the details). In my case, it was all or nothing. I chose not to install any of their apps and started using other apps in their place. Google is your Friend
  bmp2png.exe error on DVD flickBy almutazilah in forum Authoring (DVD)Replies: 4Last Post: 5th Nov 2011, 16:16
  "ERR: MuxMan error!" while Creating DVD in GfDBy michcio in forum Authoring (DVD)Replies: 2Last Post: 6th Dec 2008, 19:05
  DVD Flick error message "ffmpeg.exe has stopped working"By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 08:20
  Get many error messages, AviSynth error message and meGUI errorBy MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
  SVCD2DVD error on start up 'Application has generated an exception...'By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 04:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
