I bought one of these and after a few set up glitches thought I had it working properly using the HD cable supplied. Very happy with the picture quality.
Now the problem. I watched a dvd no probs.....then on chapter 18 of the last 4 discs its stuck never to move again untilI take the disc out.....any idea's...???
Am dissapointed as I got it for £35 from Aldi the picture quality is superb.when its working...
Hope you can help and any other advice would be greatfully received as the instruction booklet is basis and website only lists same booklet, no advice etc.
Thank you ,
Denny91.
If the player can't play back discs properly, then it is likely faulty. Exchange it for another one. There isn't anything you can do to make function correctly. It is a DVD player, it should be able to play DVD's.
Google is your Friend
Tevion 8001
By vickerps in forum DVD & Blu-ray PlayersReplies: 11Last Post: 15th Nov 2010, 08:49 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 13:35 -
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 07:40 -
Problem with Tevion HDMI DVD player
By Buna3000 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Oct 2007, 12:43 -
TEVION 8000 / 8001 HDMI DVD PLAYER problems with picture freezing....
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 10:56
