Hi Everyone,
I'm creating an application that will record video files which will be used as the input to a DVD authoring program. I've read that DVD video is based on MPEG-2 but what exactly does that mean in terms of the authoring process?
If my application encodes files in MPEG-2 format directly, does that mean that the files won't need to undergo any type of conversion when they're authored to DVD? If it makes any difference, I would like the DVD to be readable in any standard DVD player.
Thanks!
Kris
Seems you have a bit of homework to do. Look to the left and start reading the various guides, and how tos.I'm creating an application that will record video files which will be used as the input to a DVD authoring program. I've read that DVD video is based on MPEG-2 but what exactly does that mean
Thanks MysticE. I definitely don't mind doing some reading. Could you point me to one or two that you think would be the best starting point for me?
Thanks!
Kris
Authoring DVD's with .flv files
By kasfig in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2012, 12:05 -
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
MP4 conversion to mpeg for DVD authoring
By npereira in forum Video ConversionReplies: 8Last Post: 2nd Jun 2009, 05:20 -
How do I identify faults in MPEG files? Authoring programs crash...
By semmel in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2008, 23:28
