Hi
I want to convert a DVD to .avi or something similar. The DVD contains Video_TS and Audio_TS. The weird thing is, that the Audio_TS folder is empty but the sound works when I watch it. Thus, I assume, the sound is somewhere inside the Video_TS folder. For example, I watched the DVD with VLC, and left the Audio_TS folder out (I didn't drag it into the playlist), and it worked fine. Now, as I mentioned, I want to convert the whole DVD, so, also the sound. I tried it a few times, the picture always works fine, but I just never have any sound. I tried a few things, for example I added the Video_TS as audio... I am just not really familiar with converting and stuff, thus I hoped someone from here might be able to help me? I would really appreciate help! Thank you!
I was using ffmpegX, I tried avi and mpeg with different encoders (or components).
Thank you for the link to this application, I will try it with this one, hopefully it will work.
Edit:
Oh, sorry, I forgot to mention that I am a Mac OS X user, and apparently the application only works for windows. -
Oh. Then I'm not going to be much help to you because I don't know anything about macs.
I noticed you posted in the newbie/general discussions forum. You might get better luck in the mac forum.
https://forum.videohelp.com/mac-f9.html
Mabe a mod will move this thread for you.Donadagohvi (Cherokee for "Until we meet again") -
Have you tried using the guide? https://www.videohelp.com/guides/guide-to-dvd-video-ts-folder-to-divx-conversion-with-f...pegx-id321#321
Maybe you are missing step or two.Google is your Friend -
What often confuses newbies is that the audio_ts folder does not contain the audio track of your movie. So, it should normally be empty. The audio track is muxed with the video track (.vob files) inside the video_ts folder.
On macs, *by far* the easiest way to convert DVDs into divx avi is to use D-vision3. Not only is it totally free, but its user interface is particularly friendly for pros and newbies alike. I highly recommend giving that a try. Unlike many other tools that do similar tasks, you have to work hard to screw up a conversion with D-Vision3. -
Thanks a lot for your help! I managed to convert the DVD properly now!
Problem with surround sound. Works why Im playing the TV but not with a DVD
By marionr26 in forum AudioReplies: 3Last Post: 15th Feb 2010, 17:28 -
AnyDVD to TsRemux , works but no sound on ps3 ?
By krohm in forum Blu-ray RippingReplies: 8Last Post: 5th Aug 2009, 05:46 -
mpeg TS files works with no sound on sony vegas what i do/??
By khalid81 in forum EditingReplies: 11Last Post: 20th Jul 2009, 10:20 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22
