I finally managed to setup a working HDMI recording solution. I am able to record from my cable box and produce an avi file with a PCM 2ch embedded. I then have to use besplit to extract the ac3 from the wave file that I get from the avi. What is the best program to make a Blu Ray out of these files? I also need to be able to resink the ac3 file to the video, because the besplit ac.3 file is 6 seconds shorter. I also need to do 3/2 pulldown and convert to h.264. I can do all this with Adobe CS3, but I have to use three programs(premiere, after effects for the 3/2 pullldown and encore for the Blu Ray). Is there a program that can do it all in just two steps(capture, do 3/2 pulldown while converting to h.264)? Right now, I have to do it in three steps and the files are just huge(2 hour movie is 859GB).
Here is what I am using:
SA8300HD
Dtronics DD-D12p
Gefen DVI+SPDIF to HDMI to combine the DVI and the SPDIF
Blackmagic Intensity HDMI Capture Card
Thanks in advance,
Chris
Seems like a lot of work just to get a movie onto Blu-Ray. Wouldn't it be faster and much easier to just RIP the actual movie?
Google is your Friend
hdmi blu-ray to tv not displaying
By BroomQueen in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th May 2011, 15:07 -
Problem with HDMI to VGA on Blu-ray
By Lio380 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Mar 2011, 19:58 -
Is it necessary for a laptop having an HDMI port if it has no Blu-ray drive
By coody in forum ComputerReplies: 7Last Post: 29th Nov 2010, 20:35 -
Need app solution to play Blu-ray ISO. Top two players failed.
By timmy2 in forum Software PlayingReplies: 4Last Post: 12th Jul 2010, 22:46 -
Blu-Ray 1080i Component VS. HDMI
By nerd_pH in forum DVB / IPTVReplies: 4Last Post: 5th Nov 2009, 12:48
