Hello
I'm a professional 3D animator with a problem (well, many - but only one relevant here).
Recently, I got this new machine at work. Big time thing with 8800 GT X graphic card and all.
Well, I used to view my animations in MediaPlayerClassic - witch i love. But on this new machine, first there was MP 11 which took over. When uninstalling, MP 9 took over. And since i couldn't make the classic MP my permanent viewer, I decided to try the VLC.
But but but... Game animations is often very short in length and i need the VLC to making an .avi preview of them.
Thing is, I’ve made the player repeat/loop the .avi file, but it doesn’t do a good a very job of that. It sort of makes a pause/break between each end and start, making any animation looks jerky. That was defently MP Classics force to make smooth transitions.
Looking through the preferences, I find nothing to indicate there’s a delay(setting)anywhere. And I find nothing on VLCs forum/FAQ. So question is, of cause, how to get rid of that?
If you have a solution or your own settings that works – please let me know.![]()
Thanks in advance
None?
Did I make it clear what i meant? Should I rephrase? try again?
Lol and here I thought this WAS the VLC forum... My Bad.
But I've tried the MPC (Or Mplayer2 as the shortcut says)vs MP9 again... the 9 wins every time. Still, if someone has an answer to make MPC permanent, please let me know.
PS. What I do to try and make MPC default Player:
1. Open MP9 > Tools> Options > file type - Untick ALL > Apply> Okay
2. Open MPC > View > options - Tick all the Avi, Mpg and wmv boxes > Apply> Okay
3. Right click the file I want played > Open With >Choose Program > MPC (Tick : Always use this program)
4. Double click the file I want played and... It opens in MP9
Do it all again with MPC first... -
Are you sure your "work" computer doesn't have these settings locked in the registry to prevent modification?
Performing step 3 only should be enough to alter playback.
You have downloaded and installed MPC right? The standalone version is mplayerc.exe (which should be the same as mplayer2.exe, but who knows).Google is your Friend
need player for demo clips - freeware, flexible and smooth transitions
By sybariten in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 19:23 -
asf playout on second monitor from playlist not smooth at transitions (WMP)
By pj0tr in forum Software PlayingReplies: 1Last Post: 3rd Sep 2008, 14:45 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player CLASSIC PlayList Problem
By pitsikoko in forum Software PlayingReplies: 10Last Post: 11th Apr 2008, 13:11 -
Media Player Classic won't automatically play the next MPG in a playlist
By dmcmurphy in forum Software PlayingReplies: 0Last Post: 4th Jun 2007, 18:19
