    Oct 2007
    Hi,
    Does anyone know how to create DVDs (in this case 3) that can be synchronized to play at the same time but projected with separate projectors? Or can it be done by the way you use the DVDplayers?.
    Grateful for help.
    /i
    Apr 2004
    Miskatonic U
    Not sure what you are trying to do, but it sounds like you need to approach some professional event suppliers to get equipment that will play in sync. It not something you can author for and do with standard consumer kit.
    Read my blog here.
