Hello All,
I just tried Movica for joining a number of separate WMV clips I had , it was just the right software I was looking for. It simply stitches the inidividual files together without recoding / recompression which was happening in a number of other softwares I tried. Infact recompression always was a hassle due to loss in Bit Rate and Audio/Video Quality. And i had to play around in the WMV Encoder Profiles for correct outputs.
However Movica lacks one feature of having an option to define multiple sets of individual files and having multiple resultant final files, and then execute the whole process at once which can keep working.
This is one thing which would really cut down the re-work of assigning separate sets of file only one by one. If someone can quote the ASFBIN utility script example ( -i file1.wmv, file2.wmv -o file1+2.wmv, -i file3.wmv, file4.wmv -o file3+4.wmv) then it would be a big help if its possible in this utility, I believe Movica uses ASFBIN to cut/edit/join the WMV/ASF files.
Regards,
AlterEgo
Results 1 to 1 of 1
Help with ASFBin
By bartman99 in forum EditingReplies: 0Last Post: 13th Jul 2010, 07:17 -
Movica 6.6 beta - spyware? joining few wmv files & wants to contact Goo
By suzanne27 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2009, 18:15 -
batch joining video files
By pengocha in forum EditingReplies: 3Last Post: 27th Oct 2008, 09:52 -
batch joining multiple .001 files
By vitamine in forum EditingReplies: 8Last Post: 22nd Sep 2007, 16:57 -
Batch joining into separate files
By Bratac in forum EditingReplies: 0Last Post: 20th Aug 2007, 08:02
