I have a wmv file that I need to convert to DVD...what is the best tool for this? Thank you.
It depends on the quality and resolution of the original. WMVs can also have variable framerates, which can make them difficult to convert.
If the original is at least 640 x 480 then ConvertXtoDVD should be able to do it. FAVC would probably work as well.
If the resolution is lower, give FAVC a go because you can choose half-D1 for the encoding resolution.Read my blog here.
FAVC or DVD Flick are great choices (and they're both freeware). Just be sure to switch the settings for whichever program you choose to "Slower encoding" (which should result in an output file that looks exactly like the input file); and also, in the case of DVD Flick, enable "2 Pass Encoding".
Just remember the golden rule for converting footage:
"Crap in, crap out!"
DVD to WMV converter that does multi-channel audio
By smitbret in forum Video ConversionReplies: 18Last Post: 6th May 2011, 14:14 -
looking for WMV-to-AVI converter
By snadge in forum Video ConversionReplies: 2Last Post: 18th Feb 2010, 16:36 -
DVD to WMV Converter! Recommendation please
By dawson in forum DVD RippingReplies: 3Last Post: 2nd Nov 2007, 08:39 -
best/fastest wmv to dvd converter
By BroomQueen in forum Video ConversionReplies: 2Last Post: 12th Oct 2007, 19:31 -
Looking for DVD to WMV converter!
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 12th Oct 2007, 07:14
